It is currently Mon Nov 09, 2026 12:21 am
Vehicle: 88 1ltr zook
Post Posted: Sat Jan 07, 2012 2:13 am
is it possible to do and would it make it "better" highway vehicle?
when boredom sets in ....
Post Posted: Sat Jan 07, 2012 2:25 am
A 1.6 would......
Yes and no, not really.
The coiler case has a slightly taller high range so highway revs will drop, but that might not be a good thing - I don't think there is any evidence that a sierra is revving too fast on the highway in stock form- you might not be able to use 5th gear as much, for instance.
A coil case should be quieter, but I would have thought it should be pretty much undetectable - there's enough other noises going on that isolating what's coming from just the case would be hard I think.
Post Posted: Sat Jan 07, 2012 4:23 am
im thinking g16b with five speed box and coily transfer, does anyone know if you can mount the handbake assembly to the coily transfer case?
Post Posted: Sat Jan 07, 2012 4:27 am
If you only want taller gearing, you would be better off with w/t diff's...
Post Posted: Sat Jan 07, 2012 4:45 am
:no: :no: WT gears like mr.stekky said would help a tiny bit
Post Posted: Sat Jan 07, 2012 5:06 am
I've got standard size tyres and 6.5 transfer gears in my zook at the moment and even with the high revs it's getting way better fuel economy than I ever have on various tyres from 28's to 34's.
Users browsing this forum: No registered users and 119 guests
