| coily tansfer in nt leafy https://auszookers.com/forum/viewtopic.php?f=5&t=29335 |
| Author: | juzzys [ Sat Jan 07, 2012 2:13 am ] |
| Post subject: | coily tansfer in nt leafy |
is it possible to do and would it make it "better" highway vehicle? |
| Author: | steak_knife [ Sat Jan 07, 2012 2:25 am ] |
| Post subject: | Re: coily tansfer in nt leafy |
A 1.6 would...... |
| Author: | Gwagensteve [ Sat Jan 07, 2012 2:25 am ] |
Yes and no, not really. The coiler case has a slightly taller high range so highway revs will drop, but that might not be a good thing - I don't think there is any evidence that a sierra is revving too fast on the highway in stock form- you might not be able to use 5th gear as much, for instance. A coil case should be quieter, but I would have thought it should be pretty much undetectable - there's enough other noises going on that isolating what's coming from just the case would be hard I think. Steve. |
| Author: | juzzys [ Sat Jan 07, 2012 4:23 am ] |
im thinking g16b with five speed box and coily transfer, does anyone know if you can mount the handbake assembly to the coily transfer case? |
| Author: | steak_knife [ Sat Jan 07, 2012 4:27 am ] |
If you only want taller gearing, you would be better off with w/t diff's... |
| Author: | Rusho [ Sat Jan 07, 2012 4:45 am ] |
juzzys wrote: im thinking g16b with five speed box and coily transfer, does anyone know if you can mount the handbake assembly to the coily transfer case?
WT gears like mr.stekky said would help a tiny bit
| Author: | GRPABT1 [ Sat Jan 07, 2012 5:06 am ] |
I've got standard size tyres and 6.5 transfer gears in my zook at the moment and even with the high revs it's getting way better fuel economy than I ever have on various tyres from 28's to 34's. |
