https://auszookers.com/forum/
any one know the weight of an IFS hilux steering box?
https://auszookers.com/forum/viewtopic.php?f=5&t=29395
Author:  tanshi [ Mon Jan 09, 2012 12:04 am ]
Post subject:  any one know the weight of an IFS hilux steering box?
Im getting one shipped from the states but the guy tells me the cheepest shipping ge can find is with DHL and its gonna cost $530
I get stuff shipped from lowrange heaps cheeper than that so im hoping to give him a hand finding some cheeper way of shipping it/them. he has 2
Author:  Fatzook [ Mon Jan 09, 2012 12:59 am ]
Post subject:  Re: any one know the weight of an IFS hilux steering box?
Won't they be left hand drive? :?
Author:  Gwagensteve [ Mon Jan 09, 2012 1:08 am ]
Yep, and that makes it perfect for a sierra as the result is a strong box with lots of pitman arm options that bolts to the inside of the RHS chassis rail.
Author:  BlueSuzy [ Mon Jan 09, 2012 1:18 am ]
So you have to put the radiator somewhere else..
A 60 series Landcruiser box with Pitman arm is 14Kg, According to my bathroom scales.
They are a very similar size to an ifs box.
Mounts outside chassis and pitman arm faces forward. I would run this box if i still ran leafs (no panhard mount)and didnt have a chassis number in the way.
Author:  tanshi [ Mon Jan 09, 2012 1:31 am ]
Yeah LHD, i measured up a RHD one and there are smaller than a Vitara power steer box in most dimentions. only radius is bigger.
If i can get the shipping reasonable, i think $40 for a box is perfect.
edit: Its going in an LJ so the radiator isnt an issue cost they sit up higher as standard than a sierra.
Author:  BlueSuzy [ Mon Jan 09, 2012 1:35 am ]
Smaller than vit? Looks bigger than my old vit box.
Author:  neofitou [ Mon Jan 09, 2012 1:35 am ]
Low Range use UPS, they use some sort of standard box deal with a flate rate for what you can shove in that one box.
UPS Worldwide Express Saver $260 for a '10kg' box with 10kg in it.
Im not sure if thats the box they are using. But its about half the cost of the other UPS options, like your own box but choosing thier "cheapest shipping method".
You should have bought the box from low range..
Author:  tanshi [ Mon Jan 09, 2012 1:37 am ]
the one i measured was 30mm shorter top to bottom,
30mm shorter on the horizontal. but 20mm bigger in diameter of the body.
it was the older style one, rather than the newr one which is bigger again
Author:  tanshi [ Mon Jan 09, 2012 1:39 am ]
low range would probably ship one to me from around $65 using USPS.
however, they sell boxes for $300+
the boxes im looking at getting are $40
so theres a fair bit of difference.
If it comes down to it i will just buy a rebuilt one from LOwrange
Author:  BlueSuzy [ Mon Jan 09, 2012 4:17 am ]
ahk. I will have to measure my one. Off an 86'ish old surf.
Author:  Highway-Star [ Mon Jan 09, 2012 4:52 am ]
For what its worth, the old man's came off about a '91ish RN110 Extra Cab IFS job.
Author:  tanshi [ Mon Jan 09, 2012 5:10 am ]
29 lbs weight, USPS will ship for $163
alot better than $500 odd.
Lowrange say they can ship through DHL for $130
