| Line Locks with a tap! https://auszookers.com/forum/viewtopic.php?f=5&t=29468 |
| Author: | SierraDan [ Wed Jan 11, 2012 7:20 am ] |
| Post subject: | Line Locks with a tap! |
Has any body used the Trail Tough line lock kit that uses a tap as opposed to the button and electric ones? Or anybody got any opinions on them? http://www.trailtough.com/index.php?pag ... &Itemid=53 Cheers. |
| Author: | 31zook [ Wed Jan 11, 2012 7:21 am ] |
| Post subject: | Re: Line Locks with a tap! |
nope, you can buy one or two of my elec line locks if you want... |
| Author: | Gwagensteve [ Wed Jan 11, 2012 7:37 am ] |
I'll weigh in: I think these are cool for cars with no park brake. For use on the move, I think they are a bad idea. Firstly, they aren't a one-way valve so you can't have "another bite" you have to get brake pressure right and then crank the lever. If I drive up to something, hit the brakes, line lock it, and the car creeps, I can just pump the pedal until it stays put. You have to plumb the brake lines to somewhere you can easily reach the lever. This might make bleeding a PITA. You don't have fingertip contra. You have to yeah to wherever the lever is and turn it. I have a momentary switch on the gear lever on piggles, and a constant switch. I can park the car on the constant switch, get in, put it in gear, clutch, then, with one finger on the momentary switch, turn off the constant switch - the car doesn't move. A millimetre. Then bring the clutch in and when I feel it load up, lift my finger and the car is away without any rollback. I"m not saying that's impossible with a manual valve, I just think it's much harder. And in any case, an electric line lock is cheaper. http://www.lowrangeoffroad.com/index.ph ... k-kit.html I think in reality these are two different tools for different jobs. I love my line lock. Steve. |
