https://auszookers.com/forum/
Wire colour standards
https://auszookers.com/forum/viewtopic.php?f=5&t=29471
Author:  Bugsta [ Wed Jan 11, 2012 8:20 am ]
Post subject:  Wire colour standards
I have just made a bracket for my new Fuse and relay block and about to start on some major cabling in the Jim.
Can anyone point me to a general colour standard used for various types of systems please. I just like to use some common code. ie...
Horn - blue
Spot lights - Orange
Rear work/reverse light - white
Note - I don't have many multi colour wires, mostly solids.
I will end up with 3 main power sources - BATT, ACC, IGN.
Black, Brown, Red, Orange, Yellow, Green, Blue, Grey, White. I do have a grey/red and a few Fig8 multi colours. Range from about 5Amp to 15Amp. I have ~40Amp Red and Black.
Here's the bracket. I plan to weld the 2 parallel stems to the top support and I might install some nutserts into the firewall and once I'm satisfied with it all.
Author:  steak_knife [ Wed Jan 11, 2012 8:26 am ]
Post subject:  Re: Wire colour standards
8O what do you need 16 000 000 fuse's for?? 8O
Author:  alien [ Wed Jan 11, 2012 8:29 am ]
maybe pushing them in and pulling them out is like bubble wrap to him? =)
Author:  steak_knife [ Wed Jan 11, 2012 8:35 am ]
MMmmmmmmm, poppy :D
Red power, black earth, go nut's with the rest just make a diag for when it shit's it's self.
Author:  Bugsta [ Wed Jan 11, 2012 8:39 am ]
Well, I don't need... 16(!) fuses, but in the modular units I got, that's what the are. I can add extra relay blocks if I need to. These blocks are semi sealed to. And I got extra places for fuses if I need.
Author:  badonkadonk [ Wed Jan 11, 2012 8:59 am ]
What; you never hooked up a flux capacitor before?
Author:  steak_knife [ Wed Jan 11, 2012 9:03 am ]
Nope..... 8O
Author:  Rusho [ Wed Jan 11, 2012 9:08 am ]
It's for the Brocky 'Energy Polarizer' :lol:
Author:  Bugsta [ Thu Jan 12, 2012 10:42 am ]
I am thinking of hinging the unit to allow it to be pushed up. Any suggestions of a suitable hinge?
edit: or 2 smaller hinges
Author:  masterA [ Fri Jan 13, 2012 12:08 am ]
WOW...that is one big fuse box!!!!
Hope you got good diagrams and you're good at trouble shooting coz if you're pulling out all the wires and re-wiring the whole car that's going to be one big job
GOOD LUCK!!!
Author:  Bugsta [ Sun Jan 15, 2012 6:35 am ]
Not rewiring the whole car, and as stated, I don't plan to use the entire amount of fuses, thats just how it comes when you want a modular system. The box on the left holds 16 fuses and the right holds 4 relays, which is just enough. I can ad a third relay module if I need ata later date.
And yes, I have started by making a table of switches/types, fuses, relays, current etc so I have a starting point for what I needed. I have most of the circuits in mind but will draw them all up and note colours used for each.
