Joined: Wed Oct 05, 2011 9:12 pm Posts: 23 Location: South Australia
Posted: Wed Jan 11, 2012 9:42 pm
Hi all,
It's been a while. Late last year I bought my Sierra and after a few days of driving around and loving it, I noticed a terrible knocking sound. Took off the sup to find chuncks of piston No.4 sitting amoungst the oil.
Long story short I put a new G13B from a barina in (has done less than 50k) and it's all tuned and is running great. One thing I've noticed though is that I haven't had much of an improvement in top speed.
On the highway to work 90km/h the Sierra does not get there without pushing it quite hard. I recently took two of my mates home from work and it was difficult to keep it above 80km/h (top down if that makes a differnce). Am I expecting too much as far as speed is concerned?
Is there something that might be hindering my speed such as a poorly tuned carby etc?? Any guidence would be greatly apprecaited.
Import donks often have only been driven slowly,
and thus take time to re- run in.
Can be same for engines from Aus cars that only been driven carefully.
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
Posted: Wed Jan 11, 2012 10:57 pm
Should be able to cruise at 100 easily with those stock tires and a GC engine. Set/check the timing and make sure the vacuum actuator that pulls open the secondary throat has no leaks and holds vacuum. Then check that the hose to it isn't perished or blocked.
Users browsing this forum: Google [Bot] and 101 guests
