It is currently Mon Nov 09, 2026 12:31 am
Post Posted: Wed Jan 11, 2012 7:45 pm
Will a Turbo manifold from a GTI G13b fit on a G13a?
Post Posted: Wed Jan 11, 2012 7:56 pm
No.
Steve
Post Posted: Wed Jan 11, 2012 8:03 pm
Damn! the pattern looks the same!
Post Posted: Wed Jan 11, 2012 8:17 pm
engine mount ?
Post Posted: Wed Jan 11, 2012 9:14 pm
not even close !! the G13b GTi exhaust ports are round and the G13a and G13b 8v exhaust ports are rectangle, and both with totally different stud patterns.
If you want to use an exhaust manifold from a GTi then maybe (if it's not a cast turbo manifold) you could cut off the faceplate and weld on one to suit a G13a
Vehicle: '96 LWB trayback
Post Posted: Wed Jan 11, 2012 11:17 pm
Stud pattern and port size/location aside, You will almost never be able to use a manifold designed for FWD purposes (swift gti) in your RWD sierra due to the position it will locate the turbo in.
Most FWD manifolds are designed to low mount the turbo, which in our application will put it smack back in the middle of the chassis rail or engine mount.
Post Posted: Thu Jan 12, 2012 3:49 am
Its a highmount manifold, mine motor has 4 round ports and 4 square ports.
Post Posted: Thu Jan 12, 2012 4:46 am
8 port 4 cylinder exhaust manifold? :?
Post Posted: Thu Jan 12, 2012 4:55 am
Less back pressure for more flex..
Post Posted: Thu Jan 12, 2012 5:10 am
4 of those will be inlet :wink:
Post Posted: Thu Jan 12, 2012 5:29 am
bwhahahaha, i know that... but an 8 port turbo manifold would look like an octopus.
Post Posted: Thu Jan 12, 2012 8:12 am
Really????
Post Posted: Thu Jan 12, 2012 9:16 am
Really????
You for real? :crazy:
Post Posted: Thu Jan 12, 2012 9:18 am
Really????
i assume he's talking about exhaust & intake valves... :?
Post Posted: Thu Jan 12, 2012 9:38 am
Just connect them together :) perpetual motion will be created... Or am I missing something
Stocker
Post Posted: Thu Jan 12, 2012 10:01 am
Yep....one of these
Users browsing this forum: Google [Bot] and 98 guests
