It is currently Sun Nov 08, 2026 9:57 pm
Post Posted: Thu Jan 12, 2012 5:48 pm
can anybody tell me the differance between jimny manual and electric transfer cases
Post Posted: Thu Jan 12, 2012 5:54 pm
What do you want to know.
The ratios are different.
One is a manual shift (has a stick) other is electronic
Manual can be swapped into the electric spot. Will give a reduction in gearing
What kind of info do you want)
Post Posted: Thu Jan 12, 2012 6:08 pm
thats basically what i wanted to know thanks is the back side of the casing the same? and can the electric gears be put in the manual using the manual shift
Post Posted: Thu Jan 12, 2012 9:03 pm
VVT Jimny Manual
High 1:1
Low 2:1
VVT Jimny Auto
High 1.32:1
Low 2.64:1
Non VVT Jimny Auto/Manual
High 1.32:1
Low 2.145:1
Yes
No
The gearbox and diff ratios are also different between manual and auto, and VVT/non VVT. Seems no 2 models/series are the same.
Post Posted: Thu Jan 12, 2012 9:04 pm
"back side of the casing" I assumed you are talking about the prop shaft connection. Yes. Zukenutter may be able to answer if you mean something else.
Users browsing this forum: Google [Bot] and 96 guests
