| transfer gears https://auszookers.com/forum/viewtopic.php?f=5&t=3002 |
| Author: | seen [ Mon Sep 22, 2008 10:37 pm ] |
| Post subject: | transfer gears |
hey guys i hav 215 75 15 tires on my seirra n i want to drop my low range lower than stock n high n 2wd back to stock is there any kits for this bcoz all the kits i hav seen r for bigger tires |
| Author: | Taff [ Mon Sep 22, 2008 11:47 pm ] |
| Post subject: | Re: transfer gears |
if its a WT (3.7) you could go to NT (3.9) centres and gain a bit back. but 215/75R15 is so close to stock its hardly work the effort. Only 15mm in diameter difference from my rough calculations. |
| Author: | Rockhopper [ Tue Sep 23, 2008 10:57 am ] |
If you don't plan on getting any bigger tyres down the track, I'd probably go 4.16:1 transfer gears. Should be great off road. May rev a little harder on the freeway. |
| Author: | TheFrayne [ Fri Aug 07, 2009 12:11 am ] |
*BUMP* If I was to leave the F10a in (4 speed) Would this option be a help or pain in the arse?? What are the tran gear options for the 1lt? Cheers *Did have a look on search but couldnt really find the info i wanted* |
| Author: | Gwagensteve [ Fri Aug 07, 2009 2:30 pm ] |
I'm a little bit confused. It's always helpful if you provide all the details of your current setup when asking a question. As you have an F10a and 4 speed, I assume you also have a 1.0 transfer case. If you do, it already has the same high range gearing as all of the 4:1-4.9:1 transfer gears = 1.55:1 So you could fit transfer gears to roughly double your low range and there would be no effect on high range. However, if your transfer case does not have a 4WD light, it can't accept any aftermarket transfer gears. Hope that helps. |
| Author: | TheFrayne [ Fri Aug 07, 2009 3:27 pm ] |
hey mate . Yeah sorry. You nailed the set up. 1lt with switch. . Cheers for info think ill start a thread with each question listed next time. Try and cover all bases Thanks |
