It is currently Tue Nov 10, 2026 2:57 am
Post Posted: Thu Feb 02, 2012 10:36 pm
Weve got a paddock bomb thats a WT and the front Drivers capliers sticks on when the car hasnt been used for a few days.
Any ideas and what it is or might be> Or is it a replace or rebuild fix?
Post Posted: Thu Feb 02, 2012 10:46 pm
Pull calliper off and clean, regrease the slides.
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Thu Feb 02, 2012 11:51 pm
Ive had another, Piston was jamming on when hot. Just pulle them apart for a good clean.
Post Posted: Sun Feb 05, 2012 5:50 pm
THanks all
will pull it apart and give it a grease
mm wonder if some wd40 would work for the paddock bomb??
Post Posted: Mon Feb 06, 2012 2:10 pm
remydog05 wrote:
THanks all
May melt all the rubber seals...
Lil Foot!
Post Posted: Mon Feb 06, 2012 9:46 pm
For those interested I have some Hilux calipers that needed fixing, one was siezed another was completely blocked. The siezed one was a simple matter of pulling the pistons out cleaning them up, greasing up and putting back together, the blocked one had to be completely dismantled. Below is a video that helped, some vids showed using compressed air to get the pistons out but the seized ones wouldnt budge so had to be pulled out with vice grips. Also here is a pic of what is left when you completely dismantled one, I imagine a Sierra one will be similar but with only one big piston.
Made in JP. Built in WA.
Users browsing this forum: Google [Bot] and 150 guests
