It is currently Wed Nov 04, 2026 3:16 am
Post Posted: Fri Feb 03, 2012 7:51 pm
hi all , just wondering what you vitara owners think of the rancho 9000x shocks worth buying? ive got tough dog shocks but never tried any other shocks so dont know what they are like. thanks brad
Post Posted: Fri Feb 03, 2012 7:53 pm
i set mine to 3/10 and snapped my standard shock crossmember in half
leave them on the 1 setting and they are still way too big but liveable
on a sierra that is
Post Posted: Fri Feb 03, 2012 8:00 pm
ouch 8O
Post Posted: Sat Feb 04, 2012 6:47 am
RS9000's are a waste of money.
They used to cheap because you couldn't get quality shocks in long lengths with soft valving. Now you can, there is no reason to use Ranchos.
MrRocky - I've been in (and owned) cars with that and the opposite problem - RS9000's that are far too soft for the application, even when turned right up. Whilst this is unlikely in a sierra, it is possible in a vitara.
RS9000s are valved for the application, just like any other shock. If you use a 9000 "out of application" like using a shock for the rear of a leaf spring ute in the rear of a coil sprung wagon, it's quite possible for the valving to impossible to adjust properly.
Brad - I can't comment on tough dog shocks myself. What are you asking? Are you unhappy with the ride of the TD shocks? The length?
Post Posted: Sat Feb 04, 2012 10:22 am
mine were listed for an F250 and are 980 open and have a huge bore size
there plenty hard i can assure u
Post Posted: Sat Feb 04, 2012 11:21 am
I don't doubt it.
My comment was only that there's a misconception that you can adjust a 9000 to work in any application and it's false.
It's quite possible to end up with a shock that's far too stiff or soft for the application even when adjusted all the way soft/stiff because the original application was too different to the intended use.
Post Posted: Sat Feb 04, 2012 11:56 am
yeah steve its the length i want abit more flex but dont know what shocks to get. but dont get me wrong the tough dogs are great
Post Posted: Sat Feb 04, 2012 12:08 pm
How much too short are the Tough Dogs? I'd be surprised if there was much travel left in the springs that the shocks couldn't accommodate. If you have spring spacers and have therefore spaced your bumpstops down the length of the spacer, the lower shock mount can be raised to recover the travel "lost" by fitting the bumpstop spacers.
I see no advantage in having shocks longer than the spring travel. Loose springs=no added traction (with an otherwise standard suspension configuration)
Post Posted: Sat Feb 04, 2012 12:23 pm
yeah they extend right out and the spring is at full travel, but ive got 30mm spacers im about to put in just need abit longer shocks
Vehicle: 2001 XL7
Post Posted: Sat Feb 04, 2012 1:04 pm
Have thought about rancho 7000s ?
Post Posted: Sat Feb 04, 2012 1:08 pm
Steve do u know any shocks that are around the 600 open that you would recommend for the rear of a heavy lwb vit
I'm running the commo ones but find them a bit to soft
Post Posted: Sat Feb 04, 2012 1:30 pm
Bits for Vits sell these:
http://www.bits4vits.co.uk/store/vitara ... d_173.html
and while I'm not all that crazy about them, they are a solution once you add the spacers and space the bumpstops accordingly.
No, I haven't given a thought to RS 7000's. I don't think 9000's are much chop so I have no reason to consider a mono tube from the same manufacturer. The valving is likely to be waaaay too stiff.
got_bar_work - I don't think the 600 open is all that relevant - what's the required collapsed length? That comes out at about 9" of travel by my guess.
Post Posted: Sat Feb 04, 2012 3:06 pm
thanks steve, i was looking at the Shock Repositioners / Spacers they seem like not a bad idea
Post Posted: Sat Feb 04, 2012 4:20 pm
I inverted/inboarded mine to decrease the dampening effect to try and negate the stiffness a bit
Vehicle: '95 Vitara
Post Posted: Mon Jul 08, 2013 12:40 pm
Just wondering what some of these other long travel shocks are, I've been looking everywhere for em.
Thanks
James
Post Posted: Mon Jul 08, 2013 1:53 pm
Bilstein 5125's from lowrange off road.
Steve
Post Posted: Sat Jul 13, 2013 8:06 pm
I'm running Rancho 9000Xs and find them quite good turned right down to their softest setting. Still a firm-ish ride, but I'm usually carrying at least some weight in the back, so copes well with that.
Cranked up to about 8-10 I can hit corners at silly speeds and get almost no body roll. Not really suited to my application all that often, but nice to know it's there if I want it :lol: (as long as I can avoid pot-holes and speed bumps...) At that setting they feel like the old GV Tough Dog shocks I ran for a while.
Anyhoo - long story short they work quite well at their softest setting offroad, but are waaaay too long for even lifted GV coils. A long soft coil like the Calmini 3" would probably be OK, anything else is liable to drop out unless you've extended your bumpstops, which they also require.
Vehicle: 1995 2.0V6 Vitara LWB
Post Posted: Sun Jul 14, 2013 7:40 pm
how long are the tough dogs over standard...?
how old are they?
are they the adjustable tuffdogs?
would u sell them off after getting new shocks...?
Vehicle: 92 WT Sierra
Post Posted: Sun Jul 14, 2013 9:45 pm
I'm currently running them and I agree with DarkHorse, they are good when they are turned right down to their softest even ~5 on them is decent, but can be extremely harsh on the smallest of all bumps when past this. I haven't had problems with springs dropping out, but they come rather close to. The previous owner got them out of a Jeep, so unsure if the valving would be different.
Post Posted: Mon Jul 15, 2013 8:16 am
From memory the part number listed for Vitara is unique, but I didn't look that hard.
Post Posted: Mon Jul 15, 2013 5:10 pm
how old are they?
no sure on lenght
about a year old
not the adjustable ones
i would but dont know what new shocks to get
Anyone know about the OME shocks any good??
Post Posted: Mon Jul 15, 2013 5:22 pm
OME shocks are fine, I have no problem recommending them. However, if you are running more than 50mm of lift they might be too short- they are designed for stock bumpstop positions.
Post Posted: Mon Jul 15, 2013 5:27 pm
BRAD wrote:
no sure on lenght
about a year old
ok pitty about unverified length maybe if u replace them u can measure the collapsed length ans someone on here can tell if/how much longer than standard.
i had OME shocky on my jeep they were ok i put 9000xs on and they were about the same on the hardest setting and then i couls soften them for offroad but in the end i cbf crawling under a muddy car to adjust them all the time so int the end i just set them on full and left them.
Post Posted: Mon Jul 15, 2013 5:33 pm
isnt there supposed to be some ome long travel ones you can get , i think someone on here has them
Post Posted: Mon Jul 15, 2013 5:41 pm
Are they specifically valved for a vitara? ARB are pretty conservative and it would be unlikely they'd sell a shock that required bumpstop spacing to prevent vehicle/shock damage.
The whole point of using OME in my opinion is that they are properly valved for the application. You pay more, and you have to work with conservative lengths, but you should be happy with the ride. If you step outside the recommended fitment then the ARB application specific valving isn't relevant anymore.
Post Posted: Mon Jul 15, 2013 6:10 pm
yea your no wrong, might hit them up for a price cheers steve
Post Posted: Mon Jul 15, 2013 6:14 pm
are you talking about the ones that bigrig91 fitted? if so he had to chop his floor out & remake top shock mounts.
Post Posted: Mon Jul 15, 2013 6:47 pm
Or the long ones steve used to use
Just grab some 8in bilstiens
or if u have long coils go 10 and bump stop spacer
Post Posted: Mon Jul 15, 2013 7:17 pm
yea i was looking at bilsteins i think these are the 8 inch ones (bilsteins 5125)
Post Posted: Mon Jul 15, 2013 9:13 pm
You remaking top mounts?
