It is currently Sun Nov 08, 2026 1:09 pm
Post Posted: Mon Feb 06, 2012 11:28 am
Hi,
My sister is looking at buying a early to mid 2000's Grand Vitara 5 Door.
Are there any major issues with any models in this age range.
Anything I should look for when do a test drive.
Any help would be greatly appreaciated.
Shoey
2005 Jimny "PaPa Smurf"
Post Posted: Mon Feb 06, 2012 1:21 pm
There were recalls on 2004 Grand Vitaras regarding hydaulics and brakes.
Anyone had any issues?
Vehicle: 02 GV
Post Posted: Mon Feb 06, 2012 5:21 pm
mines an 02 v6 auto and fuel guzzler round town(16-18km per 100km's). i mainly do high way now so still around 11-12lt per 100km's.
I've had no problems with mine except what I've caused. had a sticky starter motor replaced at about 180k.
Post Posted: Mon Feb 06, 2012 5:46 pm
transfer case issues with them popping out of gear in the early models, believe there is a fix for this with a new syncro ring or something
Post Posted: Mon Feb 06, 2012 7:55 pm
EArly GVs suffered with t/case problems . was fixed in 03+ models.
Timing chain noise on cold start up can be an issue.
Dry/noise belt tensioner.
Tyre scrub from pore allignment
Bent gear box cross member indicates offroad use.
Tapit noise can be caused from bad service history.
Post Posted: Wed Feb 08, 2012 1:49 pm
Timing chain. Timing chain. And timing chain.
About $1300 to fix at good mech, over $3k at stealership. Check for rattle on cold start, but if oil changed every 5k shouldn't be a problem.
Vehicle: 2004 SQ625 GV
Post Posted: Thu Feb 09, 2012 9:58 pm
Got a 2004 gv and have not had issues with the brakes. All works well. Regarding other issues rear main seal is common also.
Vehicle: Samurai G16, DMax.
Post Posted: Fri Feb 10, 2012 4:12 am
Are all your GVs V6 engined? We have quite a few the J20 4cylinder 2.0s and 4cylinder 2.0 l Purgeot diesels. I'm considering a mid 2000s 5 door diesel for my next aquisition.
92 Samurai G16
DMax
Vehicle: Jeep
Post Posted: Fri Feb 10, 2012 5:22 am
I know the auto's use a lil bit more petrol than the manuals, but 16 to 18Lt per 100kms, is not good at all 8O , i think you have a problem somewhere... my mothers 03 Auto GV, is mainly used around town, and hers doesnt even come close to using that much...
I have an 01 Manual GV with 215,000kms on it, it is very economical, and it has been very reliable, and i take mine offroad and give it shite... all the problems have been mentioned... just make sure it has been regularly serviced and well maintained, preferably with a service history, not just somebodys word, and you really shouldnt have any major problems... get one with low kms, if you can find one, you will have to pay a bit more... but they are a great car ! :D
Users browsing this forum: No registered users and 50 guests
