| Author |
Message |
IN2DEP
Joined: Fri Nov 13, 2009 10:30 pm Posts: 739 Location: Hoppers Crossing
Vehicle: 95 Sierra Soft top
 Posted: Mon Feb 06, 2012 2:06 pm |
Hey just a quick one will sj80 diff centers front and back fit my 95 sierra ??
Cheers Keith
IN2DEP
 Posted: Mon Feb 06, 2012 2:37 pm |
And a very important qustion aswel, Ive done the chromly front axles witch needed to replace the 22 spline gears out and put the 26 spline, does this mean ill need to run a rear diff center up front ???
cheers
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Mon Feb 06, 2012 3:00 pm |
A) Yes and no. The rear will bolt in. The front will not fit at all.
B) Yes.
IN2DEP
 Posted: Mon Feb 06, 2012 5:08 pm |
Gwagensteve wrote: A) Yes and no. The rear will bolt in. The front will not fit at all.
B) Yes. I have the worst f-en luck with diffs grrrrrrrrrr, ive been posting on here for half a yr now and no one can help me out, just went on that website www.findapart.com.au and one wrecker from QLD has a front diff from a coily and wants to sell to me but doesnt fit grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr so i need to find to rear leafy diff centers, oh ive checked already brand new from suzuki $1200 rip off bucks
IN2DEP
 Posted: Mon Feb 06, 2012 5:11 pm |
IN2DEP wrote: Gwagensteve wrote: A) Yes and no. The rear will bolt in. The front will not fit at all.
B) Yes. I have the worst f-en luck with diffs grrrrrrrrrr, ive been posting on here for half a yr now and no one can help me out, just went on that website http://www.findapart.com.au and one wrecker from QLD has a front diff from a coily and wants to sell to me but doesnt fit grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr so i need 2 find to rear leafy diff centers, oh ive checked already brand new from suzuki $1200 rip off bucks
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Mon Feb 06, 2012 5:17 pm |
wide track or narrow track?
coiler diffs are a 3.9 ratio.
Nt is 3.9 wt is 3.7
sorry steve your wrong. you can bolt front and rear coiler centers in to wt/nt housings..
the front is a high pinion and weaker (however i didnt ever bust mine with a gti and 31' swampers driven like it was stolen some times.
if yours is a wide track your tail shafts will fit straight up 2.
you will need to swap out the side gears for 26 spline units./
what are you trying to achieve mate?
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
Gwagensteve
 Posted: Mon Feb 06, 2012 5:36 pm |
There you go. AFAIK the coil centre is unique. Can you swap side gears for 26 spline rears in a coil centre Can you put a rear centre in a coil front third member Can you a front locker with 26 spline couplers in a coil centre? I'm not having a dig - these are serious questions. If it was/is possible to do any of those things then there might be good reason to run a coil front third member for cars with lift and no need for deeper than 3.9 gears. As an aside: A high pinion front diff is stronger than a low pinion when going forwards. They are about 20% weaker than a low pinion diff in when driving in reverse, which is why 80 series got a bad reputation when they came out for breaking front diffs in reverse. half a year? viewtopic.php?f=7&t=30087Droopypete was also having a huge shed clear out late last year - there were multiple diffs - probably gone in the bin now if there were any left over. They're around - you just have to keep looking. Steve.
jonno_racing
 Posted: Mon Feb 06, 2012 7:07 pm |
Gwagensteve wrote: There you go. AFAIK the coil centre is unique. they are Can you swap side gears for 26 spline rears in a coil centre i am 90% sure you can i measured mine and it should Can you put a rear centre in a coil front third member no. diffrent size ring gear Can you a front locker with 26 spline couplers in a coil centre? yes and no. some one on here is running one as a rear center.. jimny front air locker can be made to fit
IN2DEP
 Posted: Mon Feb 06, 2012 7:21 pm |
Yeah ive Pm'ed him few days ago, but his not the only one ive pm'ed, done around 5 - 6 guys and they all said yup i got em just didnt hear back from them, probably sold them to friends or or something anyways no point crying over it
What im trying to achieve is just to find a replace ment cause both my front and rear diffs are making the most loudest noise you can imagine, but ive already changed the front diff to 26 spline gears cause i installed a few months ago the chromely axles and cv's from low range
But in saying that i can still drive the car with the 26 spline gears fitted to the front with the standard diff, how does that work ??
IN2DEP
 Posted: Mon Feb 06, 2012 7:27 pm |
Its ok i worked it out, it doesnt change the diff just the spline from the diff so you can run 26 spline axles, got it
