It is currently Sun Nov 08, 2026 5:36 pm
Vehicle: Serria
Post Posted: Tue Feb 07, 2012 8:54 pm
Ok so I have swapped out my sj80 chassis (coily) for a sj70 chassis (leafy). My question is what dramas will I encounter to get it regoed. Should I take the compliance plates from the sj70 body and put into the sj80 cab or will there be any dramas with Queensland transport. any info would be good thanks.
Sj80 cab on sj70 chassis 5inch lift 1.6 turbo inte
Post Posted: Tue Feb 07, 2012 9:28 pm
This might have been a good thing to research BEFORE doing the work.
Have you called QT and asked them yet?
Post Posted: Tue Feb 07, 2012 9:45 pm
May have to get bodgy from here.... Defiantly don't give QT your name or the cars details if you ring them, in case you have to swap the plates/numbers.
Post Posted: Tue Feb 07, 2012 9:48 pm
Better than that, pose the question as a hypothetical scenario. ie, you want to do it, but are checking first. Like you should have done in the first place.
Not sure what the rules are on using an older chassis than what the vehicle came with....specially since its a different model. Might be easier to cancel the rego on the SJ80, and register the SJ70 with a body swap.
Post Posted: Tue Feb 07, 2012 10:03 pm
did you get the body plate with the old chasis if you did just peel of the coily one and glue the other on there and regester it as the old leaf one
josh AKA Bazook
Vehicle: Serria
Post Posted: Wed Feb 08, 2012 3:40 pm
Yeah I have got all the plates the other car is in the shed.
Post Posted: Wed Feb 08, 2012 4:19 pm
youll be registering it as an SJ70 with a body swap, I reckon somebody somewhere will want a mod plate for it and somebody else will want the police to issue a new major repair or cant be id'ed vin for it
Post Posted: Wed Feb 08, 2012 5:27 pm
a smart man would have started with a registered car first and then just called it good
bit like my new red now black high soft top drover ;)
noobs
Post Posted: Wed Feb 08, 2012 8:39 pm
Technically it'll be the 70 with an 80 body, which shouldn't be a problem as the 80 had more safety features, intrusion bars etc. Even the other way around I can't think of any safety features the coily had chassis wise the WT didn't. Brakes might be the only issue if they're different, which of cause the coily would be as nothing fits a coily.
Damn lucky the chassis mounts are the same.
Users browsing this forum: No registered users and 65 guests
