It is currently Sun Nov 08, 2026 1:09 pm
Post Posted: Fri Feb 10, 2012 5:16 am
Gday all i hunted around last nite for while but didnt come up with a diffinitive answer ive just put some 40mm lifted springs in and am chaseing some shocks buy what i rrssherched last nite i need the gabriel 81318 from a fackaroo and the 81340 from a holden no to the tougher part will these work with my lifted springs and 2inch lifted shackles i hope to put scissors on it in future but had these lyin around so in they went . Will those shocks work with current setup.
Thanks
Post Posted: Sat Feb 11, 2012 8:06 am
How long is a piece of string?
The ones leaf sprung sierras normally use are
sierra rear shock use gabriel 81147 (hiace front).
These ones when compressed are 10mm longer than OME013 (shocks to suit 40mm lift), about 50mm longer than OME013 when fully extended.
Sierra front shock use 81349 (rear commodore wagon) Apparently these are a bit longer and need 25mm bump stop extensions.
As per the shocks you have listed , I know nothing about them. Measure the compressed and extended lengths of what you want, and find the shocks to suit.
I would suspect the most commonly ones used would be suitable.
However, measure it.
Users browsing this forum: No registered users and 50 guests
