Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
Posted: Fri Feb 10, 2012 5:39 pm
Well, that's what happened and I have an engine lock symbol on the dash. Oil pissing out both sides of the engine. Jason Saw me and stopped and helped diagnose the problem. Probably broken piston cap our pins. We found a hole on each side at the back. Looks Like its enter out.
_________________ If you can read this, please tip me back over
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
Posted: Fri Feb 10, 2012 5:48 pm
Something weird going on here with missing posts.....
Anyway, I saw Bugsta's Jimny on the side of the road with a shower of oil all over the road leading right to it! Popped the bonnet and found oil all over the lower sides of the block and the sump and radius arms and diff and road.
Much searching revealed a 7mm or so sized hole in the passengers side of block behind the extractors. For whatever reason, number 4 conrod has let go and gone bing bong around smashing the block to bits.
Parts required: 1 X M series block. 1 X M series crank. 1 X M series piston and rod. Possibly also oil pickup tube, stud girdle (if fitted) and various other bits.
Posted: Sat Feb 11, 2012 9:51 am
I don't think there was that much on the road. I rolled it back to the kerb pretty quickly. Wasn't pools of it. Traffic was heavy so it'd be wrapped around hundreds of car tyres by now
Joined: Tue Jun 29, 2010 4:17 am Posts: 1664 Location: Brisbane, QLD
Posted: Sat Feb 11, 2012 11:30 am
with how mofidied you car is...its obvious that it hasn't had an easy life. One would assume they would laugh as soon as you asked. But hey, its definately worth a shot. Never know, they might just supise us.
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
Posted: Sat Feb 11, 2012 1:06 pm
Bugsta wrote:
Well, I need to be reasonaly confident because it'll cost me at least $100 for a tow each way. Where I can spend $800 for an m15.
Why not ask them first and maybe take some pictures, or see if you can borrow a car trailer? A $200 gamble to take it there and back without knowing may not be the best idea.
Should this really happen to engine of this age Jason, abuse or not?
Well, you would think not but your car isn't a typical Jimny is it?
I've seen your car on big angles a few times and I'm sure the oil light has done more than flash occaisionally. The low oil pressure scenario time after time would certainly have done main and big end damage, wether it was the direct cause in this case or if it was something else is impossible to tell without a full inspection. It does seem likely to me that No4 big end bearing has spun causing a lack of lube and then the big end has had 200 thou of slop instead of the usual 1-2 thou... That much slop lets the crank hammer the rod and stretch, then snap the rod bolts. Once the rod bolts fail you have a piston and rod just waiting to get collected by the crank on the next rev and smash a ventilation port in the side of your block.
Even at a 1 in 4 chance of getting the m13 replaced, you are still better off with a m15.
Posted: Sat Feb 11, 2012 4:39 pm
IF, and thats a BIG IF! They even want to look at it, they will strip the motor to inspect, and will almost certainly find ( as Jas suggested) that there has been a lack of oil supplied to the crank on many occasions. With 23000km and the scraped and battered jungle gym hanging from your car, you won't have a leg to stand on with regards to warranty. You could argue that there was a blockage in an oil gallery, but there won't be with such low kms.
Dealers knock back GENUINE warranty claims every day, and get away with it because the customer won't fight them. In YOUR case, you (IMO) have no claim to warranty due to your usage of the vehicle been well outside the original design perameters....... and that shows!
Just bite the bullet and get a cheap M15 from a wreck and fix it yourself.
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
Posted: Sat Feb 11, 2012 5:21 pm
thats just wrong. its a competition car suck it up and wear it
Posted: Sat Feb 11, 2012 7:11 pm
Yes, I agree with pretty much all that has been said. I am under no dilusions that it hasn't had a hard life. After realising the severity of the damage, my first thought infact was to investigate an upgrade to a m15 or m16. Just depends on what is required, computerwise to go to the m16. This would be my ideal. The little bit of reading I did a while ago indicated to me that the m18 whilst more powerful, was a weaker engine, or at the least not built stronger to cope with the extra power and failed more readily in these upgrades. Also, early indications are that the m16 is a stronger engine because it was designed for the sport. I need to do further reading to confirm or redefine my understanding. Also, that the m13 ECU will cope with the extra fuel/air requirements of the engine.
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
Posted: Sun Feb 12, 2012 6:25 am
bakerboy wrote:
i'd take it there just for shits and giggles to see the look on their faces hahaha
Bakerboy if you bought it to my dealership being a dick demanding warranty you would be wrecking it out because i would call Qld Transport to come take a look at it. Two can play silly games you know. Wayne all warranty was void once you entered that first event at Coopers.
Joined: Mon Feb 14, 2011 6:19 am Posts: 3978 Location: Brisbane,samford,QLD
Posted: Sun Feb 12, 2012 6:37 am
Posted: Sun Feb 12, 2012 7:41 am
Yeah I should have never let myself get talked into doing Coopers. Whilst it was awesome fun, I didn't set the car up with that in mind. Just not designed for that.
You know, as much attention as the roll cage attracts, the cops have never even mentioned it when they pull me over. Only ever RBT, checked rego, windscreen or rear indicators. Thats it.
Posted: Sun Feb 12, 2012 11:42 am
2stroker wrote:
Yeah mate the sierra / vitara comment was just a bit of an attempt at humour, pity to hear its dead, time to start looking for another engine.
Or an LJ even
Just had a good chat to Kyser. Based on what I know and talking to him, I think my best option is a low k 1.6 from a Swift Sport. Stronger engine, and not that much bigger that I will need that many changes made to engine management. He reckons that it will run straight up, with a few external bits swapped of course, and just need perhaps some fuel pressure adjustments for best performance.
Might start making some calls tomorrow... and saving some coin.
Users browsing this forum: Google Adsense [Bot] and 71 guests
