It is currently Sun Nov 08, 2026 12:59 pm
Post Posted: Tue Feb 14, 2012 6:58 pm
hey all
would i need to get extended brake lines if i have a 60mm lift?
thanks
Post Posted: Tue Feb 14, 2012 7:08 pm
yess!!
Post Posted: Tue Feb 14, 2012 7:12 pm
F@*K
thanks mate
Post Posted: Tue Feb 14, 2012 7:18 pm
you'll be alright if you don't flex it
Post Posted: Tue Feb 14, 2012 7:22 pm
HA! :P
Post Posted: Tue Feb 14, 2012 7:57 pm
They're not that expensive - I think I got my fronts replaced with longer braided lines for about $70...
Pretty sure someone found some replacements off another car that screwed straight up, but could be wrong:
viewtopic.php?f=4&t=25326&p=547680&hilit=longer+brake+lines#p547680
I was wrong, it's a Sierra. Might still work?
Post Posted: Tue Feb 14, 2012 8:00 pm
Jimny brake lines slip straight onto a sierra and are longer but i don't know if they fit a vitara :roll:
Post Posted: Wed Feb 15, 2012 7:48 am
Rear is the problem and the breather
Just take them in to a brake shop and ask for these but what ever u need longer it's only like 50-60 each
If u don't have to much travel in the front I've seen people take them out Of the bracket on the strut and just cable tie it to the strut body for that bit more length
Post Posted: Wed Feb 15, 2012 7:57 pm
Thanks guys
Post Posted: Wed Feb 15, 2012 8:16 pm
When I first lifted my Vit I unscrewed the brake line from the last fixing point on the chassis crossmember and left it floating - worked fine at full droop. Same up front - unbolt the next point up from the strut bracket.
Breathers are a pain, gotta get around to that...
Post Posted: Wed Feb 15, 2012 8:32 pm
might do that
yeah breather is a pain in the rear it looks like it sits about the same height at the rear bumper but it is wedged in there
Users browsing this forum: No registered users and 72 guests
