It is currently Sun Nov 08, 2026 5:16 pm
Post Posted: Wed Feb 15, 2012 6:28 pm
just done a ruf on mine and went for a drive a went around a corners and the whole diff shook from side to side it was fine after i straighthen up again and slowed down but has anyone else had the same problem
lock stomp and steer no fear....
Post Posted: Wed Feb 15, 2012 6:43 pm
Search "Death Wobble"
You've changed the caster and softened spring rate. You've also changed the drag link angle and are likely running longer/flatter shackles.
You'll just have to work though the variables.
Post Posted: Wed Feb 15, 2012 6:48 pm
im running tsor shackles and ome leaves and 4 inch jeep shocks...
Post Posted: Wed Feb 15, 2012 9:05 pm
Have a look at what steve suggested.
The way with cars are they cut there own little rut in things, then when you replace one thing it upsets the rest and has a chain reaction. Like the old 1mod equals 3mods. More then likely, king pin's, worn bushes, slop in ball joints, slop in the steering box and wheel bearings will contribute.
Post Posted: Wed Feb 15, 2012 9:17 pm
i searched ruff shakes & got this memberlist.php?mode=viewprofile&u=1784 :lol:
Post Posted: Thu Feb 16, 2012 5:47 pm
Ruff is one of the nicer words thats been used to describe me :lol:
New stats in the forum are scary, shows how much I actually contribute and how much shit I talk.
Listen to the first two posts, they have the answers!
Post Posted: Thu Feb 16, 2012 6:38 pm
I have zero shakes B)
Post Posted: Thu Feb 16, 2012 8:23 pm
turns out wheels were out of balance a little and u bolts were firm/tight, but not tight/ tight
Users browsing this forum: No registered users and 97 guests
