It is currently Sun Nov 08, 2026 12:17 pm
Post Posted: Sun Feb 19, 2012 8:00 pm
Will a front Hilux driveshaft(with the double carden joint) fit into aSPOA SWB Sierra with an adapter from I seen the pendapter? But it doesn't really go into detail how to fit it in.
Will it need to be shortened and re balanced?
Post Posted: Sun Feb 19, 2012 8:04 pm
For memory they don't mate.. pretty sure the DC joint will run out of angle, especially whilst flexing!
F&R ARB air lockers, lux diffs, 4 link coil rear,
You are better off getting a custom shaft made with high angle yokes, as they will have atleast 10 degrees more movement than a DC joint, which runs 2 uni's, is a C&NT to fix trail side, and will need to be shortened and balanced for your application anyway.
Get a quote from hardie Spicer or Driveline services etc.
Users browsing this forum: Google [Bot] and 65 guests
