Joined: Fri Nov 26, 2010 10:57 pm Posts: 566 Location: Mid North Coast NSW
Posted: Sun Feb 19, 2012 8:00 pm
Will a front Hilux driveshaft(with the double carden joint) fit into aSPOA SWB Sierra with an adapter from I seen the pendapter? But it doesn't really go into detail how to fit it in. Will it need to be shortened and re balanced?
Posted: Sun Feb 19, 2012 8:04 pm
You are better off getting a custom shaft made with high angle yokes, as they will have atleast 10 degrees more movement than a DC joint, which runs 2 uni's, is a C&NT to fix trail side, and will need to be shortened and balanced for your application anyway.
Get a quote from hardie Spicer or Driveline services etc.
Users browsing this forum: No registered users and 457 guests
