It is currently Sun Nov 08, 2026 11:04 am
Vehicle: 02 Suzuki Jimny
Post Posted: Thu Feb 23, 2012 1:41 pm
Hey Fellas,
My rear Axle Seal is leaking pretty bad and I need to replace it. Can anyone give me some advice on the best way to do it or where I can read more information about it.
Also what tools and materials will I need. Cheers
TF
Post Posted: Thu Feb 23, 2012 2:09 pm
You will need to replace the bearing at the same time. If one is leaking it is a good idea to do the other side at the same time 'cos it will start leaking about a week later :roll: You will need a grinder, a press and basic hand tools. :wink:
Post Posted: Thu Feb 23, 2012 3:38 pm
Word of advice, don't use non geniune seals.
When I did my bearings a had a non genuine seal and a geniune seal.
You can guess what seal is fucked straight away after I put it in.
Post Posted: Thu Feb 23, 2012 4:59 pm
Look in the good tech bit I think it's in there
I love lamp
Post Posted: Thu Feb 23, 2012 5:33 pm
Basic spanner socket set chain or rope to pull out axel steel tube to press bearings on know how to bleed brakes grinder that's it from memory pretty easy once you do one side and clean the inside of your drums so it looks good until you hit mud hahaha
Post Posted: Fri Feb 24, 2012 8:20 am
Cheers blokes. Think i might let the mechanic do this one :(
Will ask if i can watch though! haha.
TF
Users browsing this forum: No registered users and 454 guests
