Joined: Sun Nov 06, 2011 12:36 am Posts: 146 Location: Melbourne, VIC
Vehicle: 02 Suzuki Jimny
Posted: Thu Feb 23, 2012 1:41 pm
Hey Fellas,
My rear Axle Seal is leaking pretty bad and I need to replace it. Can anyone give me some advice on the best way to do it or where I can read more information about it.
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
Posted: Thu Feb 23, 2012 2:09 pm
You will need to replace the bearing at the same time. If one is leaking it is a good idea to do the other side at the same time 'cos it will start leaking about a week later You will need a grinder, a press and basic hand tools.
Word of advice, don't use non geniune seals. When I did my bearings a had a non genuine seal and a geniune seal. You can guess what seal is fucked straight away after I put it in.
Joined: Fri Aug 26, 2011 3:17 pm Posts: 1286 Location: Melbourne
Posted: Thu Feb 23, 2012 5:33 pm
Basic spanner socket set chain or rope to pull out axel steel tube to press bearings on know how to bleed brakes grinder that's it from memory pretty easy once you do one side and clean the inside of your drums so it looks good until you hit mud hahaha
Users browsing this forum: No registered users and 163 guests
