| Author |
Message |
experament-u2
Joined: Thu Feb 05, 2009 10:30 pm Posts: 267 Location: Adelaide
Vehicle: 98 Maruti
 Posted: Tue Mar 06, 2012 10:54 pm |
im in the middle of completing a g16b conversion into my wt sierra and i have noticed my stock 1.3 accel cable wont reach, what have others used instead? its for a g16b out of a vitara (dizzy model, intake crosses the rocker cover)
cheers
adamp493
Joined: Sat May 28, 2011 7:50 pm Posts: 75 Location: canberra ACT
 Posted: Wed Mar 07, 2012 5:14 am |
i just used the standard vitara one. i just put the pedal end through the fork and placed a nut and bolt through the hole in the pedal that is already there can take a photo if needed
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Wed Mar 07, 2012 5:17 am |
Ive used one from a sv21 camry, only as I had no vit one and the wreckers are full of camrys
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Wed Mar 07, 2012 5:54 am |
I used a tbi swift cable, and changed the end of the pedal to suit.
Steve
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Wed Mar 07, 2012 7:17 am |
I modified the stock one and used go kart cable clamps to make it awesome.
experament-u2
Vehicle: 98 Maruti
 Posted: Wed Mar 07, 2012 10:08 pm |
adamp493 what kind of vitara cable did you use, a efi or carby? im guessing efi i think i will go down the lines of a efi cable.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Thu Mar 08, 2012 9:15 am |
I use a Vit cable in my Sierra. Same car the motor came out of. (94 SWB EFI).
I have heard that Vit cables can be hard to get. If I needed one I'd probably look at Camry like AJSR said.
adamp493
 Posted: Thu Mar 08, 2012 7:12 pm |
sorry was an efi cable easiest option if you have one
Rossco
Joined: Fri May 28, 2010 10:28 am Posts: 529 Location: Townsville, QLD
Vehicle: 91 WT 1.6EFI
 Posted: Mon Jun 25, 2012 4:41 pm |
adamp493 wrote: i just used the standard vitara one. i just put the pedal end through the fork and placed a nut and bolt through the hole in the pedal that is already there can take a photo if needed I have a vit efi cable but its still to short? I'm having trouble visualizing what adamp is talking about. Does anyone have a picture of what they've done. Here is what I have.
reeceh
Joined: Thu Apr 29, 2010 8:45 am Posts: 1230 Location: Brisbane
 Posted: Mon Jun 25, 2012 4:47 pm |
That looks like a vitara carby one.
I used a swb efi cable. wacked it in the bracket. Pushed it through the firewall. Then put the little cylinder bit on the end of cable through the fork in the top of the pedal then clamped the fork around it super tight.
Rossco
 Posted: Mon Jun 25, 2012 4:53 pm |
right that might explain my problem then. I'll try the wreckers tomorrow for an efi cable then.
reeceh
 Posted: Mon Jun 25, 2012 4:59 pm |
yeah mate grab a efi cable for 1.6. Im pretty sure suzi store sell em but there hell expensive.
