| Brake caliper & pad grease https://auszookers.com/forum/viewtopic.php?f=5&t=31387 |
| Author: | TheOtherLeft [ Fri Mar 23, 2012 5:25 pm ] |
| Post subject: | Brake caliper & pad grease |
Hiya all, I'm servicing my wife's Mirage brakes and am curious as to what type/brand of grease is recommended for the brake caliper pin and the back of the pad? On the back of the old pad there's copper grease but the caliper pin is looking rather dry. In my GV there's no requirement for grease on either the pin or pad so am not sure what to use. Thanks, Ben |
| Author: | Scrawny [ Fri Mar 23, 2012 6:54 pm ] |
| Post subject: | Re: Brake caliper & pad grease |
All caliper pins need grease. I usually use a moly grease |
| Author: | fordem [ Sat Mar 24, 2012 4:18 am ] |
I use Permatex Ultra Disc Brake Caliper Lube synthetic lube on the slide pins ![]() and Permatex Disc Brake Quiet on the back of the pads ![]() The disc brake quiet is also available in a two pouch blister pack that's enough to do both calipers if you don't want to buy a can. |
| Author: | twitchy [ Sat Mar 24, 2012 6:39 am ] |
Be careful because Scrawn uses grease on the front of his pads too ......bahahahaha.
| Author: | Scrawny [ Sat Mar 24, 2012 8:23 am ] |
twitchy wrote: Be careful because Scrawn uses grease on the front of his pads too ......bahahahaha.Brakes only slow you down |
| Author: | TheOtherLeft [ Sat Mar 24, 2012 11:35 am ] |
fordem wrote: I use Permatex Ultra Disc Brake Caliper Lube synthetic lube on the slide pins ![]() and Permatex Disc Brake Quiet on the back of the pads ![]() The disc brake quiet is also available in a two pouch blister pack that's enough to do both calipers if you don't want to buy a can. I was about to buy the green permatex brake lube but I've read a few reviews about it swelling some rubbers in contact with the caliper pin. Mostly with Mitsu's and Toyotas. I was going to try the CRC equivalent as there's less reported problems. Has anyone used the CRC products with success? Was going to use copper grease on the rear of the pads. |
| Author: | fordem [ Sat Mar 24, 2012 11:40 am ] |
Let's just say in five years I've had no problems - package says it's safe for use on rubber. |
| Author: | TheOtherLeft [ Sat Mar 24, 2012 1:27 pm ] |
fordem wrote: Let's just say in five years I've had no problems - package says it's safe for use on rubber. What other cars have you used them on? Any Mitsu's or Toyotas? |
| Author: | atari4x4 [ Sat Mar 24, 2012 1:49 pm ] |
i use a smear of castrol rubber grease (red) on the caliper pins |
| Author: | fordem [ Sun Mar 25, 2012 2:49 am ] |
TheOtherLeft wrote: What other cars have you used them on? Any Mitsu's or Toyotas? Yup & yup - a Pajero & a Corolla. |
