It is currently Sun Nov 08, 2026 6:34 am
Post Posted: Mon Mar 26, 2012 1:25 pm
Hey guys, have just put the body lift in my coily yesterday arvo, after lowering and getting into pos i have then gone to move through the gears, 2nd and reverse are very tricky to get into. (hitting on the gear boot housing)
I then loosend up jacked up and tried rolling the chassis into a better pos for the gear stick, but after lowering and tighting again, same problem.
I was wondering if any1 else has had this problem? common? Do i alter my gear stick? (chop and weld)
Thanks heaps
Post Posted: Mon Mar 26, 2012 1:35 pm
yes very common problem..
on a leafy its the 4wd stick that hits,, cut a 1x1 inch notch into the tunnel and fold the metal under,
then put a slice in the gear boot..
never had a problem with the gearbox gearstick though? (on a 93 leafy)
Post Posted: Mon Mar 26, 2012 1:47 pm
If you look at the gear shift boot, there is usually an inner and outer boot. Trim away the inner. Failing that do as mentioned above :peaceout:
Post Posted: Mon Mar 26, 2012 2:05 pm
cheers guys, i just pulled the floor up then as last nite i clndt b f'd havin a look and im goin to trim the inner plate as u mentiond rusho.
thanks very much for the help.
Vehicle: SJ80, SE416
Post Posted: Mon Mar 26, 2012 2:24 pm
No need to cut the tunnel. Just unbolt the rubber boot, move it backwards/down the tunnel where it feels comfortable and tape or screw fix it into position.
Users browsing this forum: No registered users and 133 guests
