It is currently Mon Nov 09, 2026 11:49 am
Post Posted: Tue Mar 20, 2012 7:58 pm
as the tittle says i am having trouble starting my sj80 after doing the 1.6 conversion from my vitara
was hoping one of the zookie guru's might be able to please help
tried to upload a video but having trouble so will try and explain best what is happening
it has started a couple times then died, now im getting power to everything, and gone through the usual with plugs and leads and so forth
but when i try and kick it over, it wants to go but just wont get there and i need to pump the pedal. its almost like it is starving for fuel but checked and thats not the issue
so the question is if anyone has had or knows the problem
is it possible that my comp could be sending a fault or could it be something even more simple
any help would be awesome and i will keep trying to upload the video
Vehicle: 4wd
Post Posted: Tue Mar 20, 2012 8:00 pm
efi or carby?
If your close by I can come over for a look some time.
Watch out or you'll get sued.
Post Posted: Tue Mar 20, 2012 8:05 pm
sorry efi and im in canberra
Vehicle: 4wd
Post Posted: Tue Mar 20, 2012 8:08 pm
Did you try tauntons? viewtopic.php?f=5&t=29935
What suburb?
Post Posted: Tue Mar 20, 2012 8:17 pm
nah took it to a place in tuggers paid for the tow truck twice and 300 bucks got told thay started it was just the starter motor, i then replaced it and found out the timing was way out and they diddn't bother to check which i asked for so i got ripped
so worked out a few probs myself and am hoping this is the last one
in gordon by the way
Vehicle: 4wd
Post Posted: Tue Mar 20, 2012 8:19 pm
Im on the other side. There are a few members on here that live down there and may be able to help.
I think tauntons still do mobile visits :)
Post Posted: Tue Mar 20, 2012 8:29 pm
might hit them up tomorrow
living on apprentice funds so fingers crossed there call out fee isn't to damaging to the wallet :)
Vehicle: Vitara G16b , Sierra G16b
Post Posted: Tue Mar 20, 2012 9:19 pm
I would Check for an air leak between AFM and the T/B. I had a similar problem and it ended up being a split in the air pipe on that bend just after the AFM. If all good go back to basics...check fuel and spark. Good Luck
Vehicle: 97 Coily, Winch Comp Vitara
Post Posted: Wed Mar 21, 2012 3:08 am
I had similar trouble with mine, have a read of this might be the same problem
viewtopic.php?f=5&t=30564
Post Posted: Wed Mar 21, 2012 8:24 am
Which fuel pump are you running?
Check to see if the injectors are actually spraying a mist while it is running, or turning over.
Post Posted: Wed Mar 21, 2012 3:45 pm
running the vitara fuel pump in my coily tank
suzukisport how did the auto elec fix the code fault?
Post Posted: Wed Mar 21, 2012 4:22 pm
take the dizzy adjusting bolt out and rotate it a bit one way and see if that helps if not go the other way. mine was a tooth out and had similar issues unit corrected.
Post Posted: Wed Mar 21, 2012 5:17 pm
tried rotating the dizzy when i did the plugs didn't help unfortunatly as far as i can tell the timing is alright took the cover off and had a look after i got it back from the auto elecs
on the same note when checking the timing belt to make sure it hadn't slipped any teeth as the donor car had been in an accident, i used the single line that looked like an I as my guide on the camshaft sprocket
was this correct
Vehicle: 98 Maruti
Post Posted: Thu Mar 22, 2012 3:03 pm
Hi mate I have being having a similar problem getting my 1.6 started in my Sierra,
This is what my timeing marks look like.
But I have a few extra marks including a second I style mark on the bottem right side
Post Posted: Thu Mar 22, 2012 4:03 pm
that is exactly what i used to line mine up as i was sure it had slipped some teeth so i had know way of setting it otherwise
but do u know if they are the correct markings?
Post Posted: Thu Mar 22, 2012 5:04 pm
See how the cam gear is dowelled in the E hole....
Pretty sure you should use the E timing mark.
Suzuki use the same gear on the twin cam GTi which uses the I mark.
Post Posted: Thu Mar 22, 2012 5:48 pm
so should i use the i or e because when searching the net it comes up with different looking cam gears for the vitara, but because i have that cam gear should i be using the i like the gti?
Post Posted: Thu Mar 22, 2012 5:58 pm
why not just rip the rocker cover off and check for yourself? The rockers should have slight movement in them when the valves are seated ie TDC firing stroke. This will tell you whether to use either the I or E marking.
Lil Foot!
Post Posted: Thu Mar 22, 2012 6:01 pm
had a mate pop over it is the i mark :)
Post Posted: Thu Mar 22, 2012 7:27 pm
err its not the I mark !!!
want33's is on the money , its the E mark . like someone else said you use the mark on the outside that is opposite where the dowel on the inside is . on twin cam engines it is dowelled on the intake cam on the I and exhaust cam on the E , on sohc 16 valve engines it is dowelled on the E , this is because its the exhaust stroke of number 1 cylinder , its actually the firing stroke of number 4 cyl ...
Post Posted: Thu Mar 22, 2012 8:16 pm
i will give that a go tomorrow and let you know how i go thank you for the input :)
Vehicle: 98 Maruti
Post Posted: Fri Mar 23, 2012 5:36 pm
i have being doing some research and i found a few very helpful sites the most being
http://www.zukikrawlers.com/showthread.php?t=16095
Post Posted: Fri Mar 23, 2012 5:43 pm
fixed the timing sounds better but still wont start
giving me the shits now :)
Post Posted: Fri Mar 23, 2012 6:09 pm
I bet you have the dissy timed to No.1
Retime it to No.4
Post Posted: Sat Mar 24, 2012 8:49 am
will give it a shot this arvo
Post Posted: Sat Mar 24, 2012 9:03 am
Any luck?
Post Posted: Sun Mar 25, 2012 5:19 pm
got it going thanks for the advice on timing it off #4, the problem was and still is when i removed the distributor to help with removing the engine i didn't mark it, as in the honda's i have worked on they only locate in one position. so now after stuffing around for a couple of hours trying new pos i got it going but its running rough and to advanced. just need to stuff around trying to get it right now.
one final question though when using the timing light should i be using #! or#4 spark lead?
again thanks for getting me to this point :)
Post Posted: Sun Mar 25, 2012 5:26 pm
Timing light still clips to No.1.
Post Posted: Sun Mar 25, 2012 5:33 pm
cool thanks will give it a go tomorrow
Vehicle: 98 Maruti
Post Posted: Sun Mar 25, 2012 10:25 pm
Bit of a hijack but mine starts now to, it was the timming that was out
Thanks all for the help
Users browsing this forum: Andygoodbloke, Google [Bot], Google Adsense [Bot] and 47 guests
