It is currently Sun Nov 08, 2026 3:57 am
Vehicle: 02 GV
Post Posted: Sun Mar 25, 2012 5:15 pm
My strut mounts need replacing, known this for a while but was told it's not a safety issue when I had struts put in.
Is this a normal thing to wear out, Anyone else replaced them cause they've worn.
They make a clunking noise and move about 2-3mm where the rubber mount is when I rock the car, I can hear it too when going over the gutter slowly going out the driveway.
looks like there called a Strut Cartridge?
I found some for sale on an American web site. http://www.autopartsexpress.com/Parts/S ... ridge.html
Just looking at fixing all the niggling minor things with the GV.
Post Posted: Sun Mar 25, 2012 6:03 pm
Yep. Also called strut top mount, or pillow ball mount. It is a consumable part of the suspension system, just like control arm bushes etc. The bonded rubber assembly will eventually fail. It is a common maintanence issue for A LOT of different cars.
Vehicle: 02 GV
Post Posted: Sun Mar 25, 2012 8:12 pm
I can't find them from Australia, is it a part I can get from repco?
looks like it has a metal bush so not possible to make it tighter to squish the rubber bush more.
part numbers
KYB - SM5366
Ebay? - FSM5244
MOOG - K90327
Monroe - 904932
Post Posted: Sun Mar 25, 2012 8:22 pm
try fulcrum at stafford if you are around the area they can usually get parts in at a good price and usually fairly quickly
Post Posted: Sun Mar 25, 2012 8:32 pm
Under new management now. Terry Quit. Baz is still there, although he looks to be less than enthusiastic about it.
Users browsing this forum: No registered users and 122 guests
