Page 1 of 1
[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
biff10
Joined: Mon Jan 23, 2012 8:41 am Posts: 56 Location: Perth, W.A
 Posted: Mon Mar 26, 2012 1:25 pm |
Hey guys, have just put the body lift in my coily yesterday arvo, after lowering and getting into pos i have then gone to move through the gears, 2nd and reverse are very tricky to get into. (hitting on the gear boot housing)
I then loosend up jacked up and tried rolling the chassis into a better pos for the gear stick, but after lowering and tighting again, same problem.
I was wondering if any1 else has had this problem? common? Do i alter my gear stick? (chop and weld)
Thanks heaps
ROAR99
Joined: Sat Jul 16, 2011 8:31 am Posts: 190 Location: brisbane
 Posted: Mon Mar 26, 2012 1:35 pm |
yes very common problem..
on a leafy its the 4wd stick that hits,, cut a 1x1 inch notch into the tunnel and fold the metal under, then put a slice in the gear boot.. never had a problem with the gearbox gearstick though? (on a 93 leafy)
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Mon Mar 26, 2012 1:47 pm |
If you look at the gear shift boot, there is usually an inner and outer boot. Trim away the inner. Failing that do as mentioned above
_________________ Shep is a closet jimny lover!!!!
biff10
 Posted: Mon Mar 26, 2012 2:05 pm |
cheers guys, i just pulled the floor up then as last nite i clndt b f'd havin a look and im goin to trim the inner plate as u mentiond rusho.
thanks very much for the help.
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Mon Mar 26, 2012 2:24 pm |
No need to cut the tunnel. Just unbolt the rubber boot, move it backwards/down the tunnel where it feels comfortable and tape or screw fix it into position.
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 123 guests
