It is currently Sun Nov 08, 2026 4:27 am
Post Posted: Mon Mar 26, 2012 4:07 pm
Ok guys I am going to place an order at Jimnybits ( unless someone can tell me where it's cheaper in oz?)
Here are the things I think I may need to comfortably lift it 3" with provision for a further 2" body lift later if desired.
3" springs/shocks
Castor corrected radius arms
Extended brake hoses
Adjustable panhard kit F and R
Pitman drop arm
Rear panhard relocating bracket
Steering damper
Shock reposition spacers
Tailshaft extenders 1"
This whole lot with wheel spacers, transfer case guards, radius arm gaurds, some extra bolts and poly bushes comes to a grand total of $2170 Aussie shipped to my door.
I know warranty problems could be an issue etc but I looked at a set of dropped radius arms on another site at $1100 plus shipping and it scared the crap outa me!
I love my country and try to support local products 100 percent but I draw the line at being plainly overcharged. Please help guys as I have no idea what bits are needed maybe more? Maybe half this stuff I don't need? Any suggestions for local guys to supply bits at reasonable prices?
Post Posted: Mon Mar 26, 2012 4:53 pm
dont need pitman arm. i asked him directly and he said you dont need it for the 3" lift (which i have, and got from JB also) he said its for massive 4" and above lift and you wouldnt notice any gains from having it on 3"
steering damper is up to you. i just took mine off.
you only need the 1 prop shaft extension for the fwd diff, rear not needed at all as theres no camber correction on the back axel causing the prop shaft to "shorten"
if you have the adjustable panhard kit, you dont need the panhard relocator bracket. (to my knowledge) i dont have one.
what are shock reposition spacers?? if they are those rear brackets for the lower mount point, they are cool. i got them also with the long bolts (but never used the long bolts, didnt want to drill my threads out)
Oh, and you know wheel spacers are illegal right?
so yeah, id drop those things. and use the money on perhaps some servicing gear from him. get a wheel bearing ringlock tool also. i know his air filters and brakes are fairly cheap too, or even some spare bushings. I regretted not buying things like that from my 1st order from JB.
MY BUILD THREAD HERE!!!!!
Post Posted: Mon Mar 26, 2012 6:14 pm
you don't need those shock repositioners if you have castor corrected rear radius arms as well as having new dampers.(but they will help for flex a little) you only need one 25mm prop spacer for the front. you don't need a dropped pitman arm, don't need panhard relocating bracket, if you have adjustable panhards, steering damper im surprised you don't already have one to stop the wobble of the stock jimny, Wheel spacers i wouldn't get they are illegal anyway, and its cheap enough to get a high negative offset steel rims anyway
and if your going a 3" lift i wouldn't bother with the body lift. 3" is all you need for 31's and unless your going to go bigger, but then your gonna need to start buying replacement CV's
Post Posted: Mon Mar 26, 2012 6:29 pm
pompoms
What this person said :) I reckon you could get 32's under there with the right bumpstop spacing :wink:
I've never heard of a jimny having a dropped pitman arm. The ORA 4.5" lift doesn't have one, nor does the D&G tuning kit. I think of you were to add a drop pitman arm, you would end up with massive bump steer, unless you change the panhard rod mount to suit. Someone please correct me if i am wrong?
Post Posted: Mon Mar 26, 2012 8:43 pm
there is one that i know of made by zanfi.it you can see it here, this one is made for a 4" lift so unless you are going that or more its not needed
http://translate.googleusercontent.com/ ... 9iIH2n7KPQ
with out it all it causes is more stress on your trackrod ends bushing, even at 4.5" lift you can get away with out having it. if your really worried add some spacers to the stock pitman arm to lower it a bit.
something that would be good to get would be HD steering and tie rods, but iv been told just welding a bit of angle iron to them does a pretty good trick.
Post Posted: Mon Mar 26, 2012 9:21 pm
I don't have a front prop shaft spacer, will have a closer look in the morning to see how extended the slip yoke is.
Rear shock lower mounts are a good idea to avoid bending shocks as it rotates the eye 90 degrees.
You'll fit 31s but I think monley can confirm that some guard trimming will be required. My 30s are a fairly tight fit in the standard guards.
Post Posted: Mon Mar 26, 2012 9:58 pm
:wink: I had these made cus i bent my stock drag link.
Post Posted: Tue Mar 27, 2012 2:47 am
Sweet thankyou fellow auszookers for the abundance of knowledge! Can't wait to order the gear and get it off the ground!
Post Posted: Tue Mar 27, 2012 10:16 am
I know that ur ORA arms mvoed ur front axle forward so now u dnt have scrubbing issues..... but does the JB arms do the same???? or they just take care of the caster
Post Posted: Tue Mar 27, 2012 10:27 am
how much did they set you back? if i may ask.
also are you using uprated ends? or just stock jimny ones. as i would think if you were they would now be a weak point for them to fail
Post Posted: Tue Mar 27, 2012 10:32 am
i would say they move it forward also, or they wouldnt be able to correct the caster properly. as the axle mounts dont move so to correct it the arms would have to be slightly longer to get more under the axle.
Its not that big a move forward my ORA arms where only like 10-20mm longer then stock for a 3" lift
Post Posted: Tue Mar 27, 2012 10:40 am
Stock ends. AFAIK Monley didn't want to have to machine his knuckles to fit bigger ones.
Post Posted: Tue Mar 27, 2012 11:53 am
They look longer in the pic in white rice's build
Vehicle: 08 jimny, 3"JB. xrox
Post Posted: Tue Mar 27, 2012 6:54 pm
Thanks guys, I was going to ask pretty much the same Question. Just ordered now from JB, unfortunatly they don't have any steering dampeners in stock so will have to wait for that. Can't wait to get it in and try it.
3" JB, 215 Hankook dynapro, Xrox.
Post Posted: Tue Mar 27, 2012 10:05 pm
u will get 31s on with 50mm lift if done correctly
dodgy brothers mechanical
Vehicle: 03 Jimny
Post Posted: Wed Mar 28, 2012 6:24 pm
I have the jb radius arms and yes they do move your diff forward. Don't no how much though
There a tad longer then the stock ones
Users browsing this forum: No registered users and 109 guests
