https://auszookers.com/forum/
G13A heads?
https://auszookers.com/forum/viewtopic.php?f=5&t=31480
Author:  Kurto [ Mon Mar 26, 2012 7:47 pm ]
Post subject:  G13A heads?
Does anyone know if I can put a 1.6 Litre head on a 1.3 Litre engine? I have a 1985 SJ51T with a G13A engine in it.. Just wanting a little more without spending a fortune. I read somewhere this was possible and the 1.6 Litre heads had bigger valves?
Author:  Fatzook [ Mon Mar 26, 2012 7:53 pm ]
Post subject:  Re: G13A heads?
You will notice very little difference, if any. Fit the whole 1.6, or don't bother. ( that is unless your 1.3L head is stuffed and needs replacing anyway)
Author:  defibros [ Mon Mar 26, 2012 11:05 pm ]
What about just 16a bottom end to a 13a head ?Will it make a lot of difference?
Author:  jdk81 [ Tue Mar 27, 2012 4:02 am ]
yes, but using g16a head and block is even better.
Theres very few legit reasons to justify using g13a head on g16 bottom end.
Author:  Kurto [ Tue Mar 27, 2012 5:52 pm ]
Yeah my 1.3 Litre head is buggered!!
Author:  2stroker [ Wed Mar 28, 2012 7:34 pm ]
Having fitted a 1600 head, manifold and carbie to a 1300 I personally think it is a good thing to do, the 1600 head and manifold flows way better than a 1300 head and contrary to common belief it does not lower compresion as the combustion chamber has nearly identical CC to the 1300. The car that it was on ran beautifully, it acceleraterd better, it held speed on open road better and generally felt like a much more willing engine. This was a bit of an experiment, there was nothing wrong with the old head so the comparison was not tainted.
