| 30's or 31's https://auszookers.com/forum/viewtopic.php?f=5&t=31488 |
| Author: | robbo92 [ Tue Mar 27, 2012 10:43 am ] |
| Post subject: | 30's or 31's |
I have an 82 model zook and ive done a 1.3 engine nd box swap and still have the 1l diffs and transfer I have 2inch lift in it and 15x7 -13 rims Should i run 30x9.5 or 31x10.5 |
| Author: | SierraDan [ Tue Mar 27, 2012 10:47 am ] |
| Post subject: | Re: 30's or 31's |
Unless you plan on reduction gears in the near future, go 30's. |
| Author: | sogone [ Tue Mar 27, 2012 2:05 pm ] |
I run about a 30.5 in my 84 1 liter with the 1 liter diffs and transfer. Reckon it works perfect. Also have the 1.3 and 5 speed. Sits on 100 comfortably and even got up to 128km/h. I think it may rev a bit high at a 100. Sounds like its doing a bit over 4000rpm. |
| Author: | robbo92 [ Tue Mar 27, 2012 4:03 pm ] |
Atm i am in the process of nt'in my wt diffs and conciderin if i should put the 1.3 transfer in and get reduction gears or just leave the 1l transfer in and have 1.3 engine box and diffs |
| Author: | Mattmorgo [ Tue Mar 27, 2012 5:30 pm ] |
If you can afford too put some reduction gears in the wt box lower then the 1l case and you will seriously never look back. |
| Author: | robbo92 [ Tue Mar 27, 2012 6:10 pm ] |
What ratio are we talkin about for the transfer |
| Author: | Jackson [ Tue Mar 27, 2012 6:13 pm ] |
Gear sets are here http://www.lowrangeoffroad.com/index.php/suzuki/samurai/transfer-case.html |
