| Author |
Message |
anastasios
Joined: Wed Aug 24, 2011 11:36 pm Posts: 58 Location: Sydney
 Posted: Thu Mar 29, 2012 7:04 am |
Hey guys,
I have a torn outer cv boot on the passenger side of my 91 JLX Vit hardtop
Spoke with my mechanic and he is recommending to change the whole shaft.
Is this overkill? Is the quality of a rebuilt/new shaft the same as OEM suzuki?
Or should I just tell him to replace the torn boot
matty_wall
Joined: Sun Feb 15, 2009 10:30 pm Posts: 989 Location: Blue Mountains
Vehicle: SJ51T
 Posted: Thu Mar 29, 2012 7:46 am |
When the boots on my vitara were rooted i was quoted $90 per boot to replace. I ended up getting whole shafts off ebay for about 150-200$ for a pair used them for 2 years and never had an issue.
fordem
 Posted: Thu Mar 29, 2012 8:11 am |
I would say it depends on the condition of the joint - I've replaced all four boots on my GV - but - if you're in the situation that matty_wall was, and trust the ebay seller, by all means save yourself a buck or two.
anastasios
 Posted: Thu Mar 29, 2012 8:20 am |
What did you search on ebay?
atari4x4
 Posted: Thu Mar 29, 2012 8:44 am |
search for Vitara CV on ebay
anastasios
 Posted: Thu Mar 29, 2012 9:08 am |
DarkHorse
 Posted: Thu Mar 29, 2012 5:54 pm |
Driveshaft as in tailshaft (transfer to diff) or CV shaft (diff to hub)?
anastasios
 Posted: Fri Mar 30, 2012 6:23 am |
Ah sorry I meant CV shaft!! lol
DarkHorse
 Posted: Fri Mar 30, 2012 2:14 pm |
Inside is simple, just unbolt from flange. Outside - undo allen bolts holding hub cover (lock selector thingy) on, remove hub cover, remove circlip, slide CV out. (Am I missing anything?)
tombutt
Joined: Sat Jul 19, 2008 11:30 pm Posts: 1917 Location: brisbane
 Posted: Fri Mar 30, 2012 9:00 pm |
Sounds right to me however u can pull the whole hub off as a single piece
atari4x4
 Posted: Fri Mar 30, 2012 9:02 pm |
what about the RHS for those not fortunate enough to have a bolt in CV on that side.
DarkHorse
 Posted: Fri Mar 30, 2012 9:09 pm |
He said passenger side, so that's what I went with  I wonder what someone would try to unbolt on the other side - diff bracket? I don't have a bolt in drivers side yet, that's on the long list of parts taking up space in my back room
DarkHorse
 Posted: Fri Mar 30, 2012 9:12 pm |
tombutt wrote: Sounds right to me however u can pull the whole hub off as a single piece Depends whether you have allen keys or sockets handy I guess...
banga
Joined: Tue Nov 17, 2009 10:30 pm Posts: 668 Location: sunshine coast
 Posted: Sat Mar 31, 2012 5:19 am |
just take note on that ebay listing for the future if you ever do need to do drivers side that listing was for a 22 spline count shaft so it would pay to pull old shaft out before buying to make sure you get the right gear.
_________________ lseries 2" body lift king springs 27" boots and a
