Joined: Fri Oct 23, 2009 10:30 pm Posts: 257 Location: Brisbane North
Vehicle: 02 GV
Posted: Fri Mar 30, 2012 10:57 am
just wondering if there's a proper way of undoing the top, obviously you undo the centre bolt but the strut shaft turns while undoing the bolt so wont come loose. you need to use a huge spanner on the plate under the bolt but i dont think theres a spanner that big. or i could use vise type multi-grips on the shaft but could damage it
It was suggested to use a rattle gun but i don't have one.
Joined: Mon Aug 13, 2007 11:30 pm Posts: 1787 Location: Butler, WA
Posted: Fri Mar 30, 2012 11:06 am
Had that problem myself Drop the whole strut top out instead (the 3 smaller nuts). Then put the big plate in a vice or similar so you can undo the strut nut.
my bad i only just read the bottom of your post. i had the same problem with mine went to a workmates place and undid them with his one then nipped them up and went home. some one on here might be local to you if you get stuck. ataris way probably be the easiest other way.
_________________ lseries 2" body lift king springs 27" boots and a
Users browsing this forum: No registered users and 104 guests
