It is currently Wed Nov 04, 2026 9:06 am
Post Posted: Sat Mar 31, 2012 7:35 am
hey, ive got a v6 vitara, and want to check if it has any faults as i dont think its running quite right, ive read somewhere about hooking up a jumper somewhere and counting engine light flashes, but i need more details, or a link, i had a search but couldnt find anything useful. thanks guys
Post Posted: Sat Mar 31, 2012 9:11 am
about half way down there first page there is a word doc that i've posted giving you the instructions on how to pull the error codes.
viewtopic.php?f=5&t=6451&hilit=j20a+error+codes
Post Posted: Sat Mar 31, 2012 12:28 pm
If the CEL isn't on, there are no active fault codes, so there's nothing to be read using the jumper method - having said that - the ECU does store codes from previous failures, but you need a reader to display them - either a Dealer's GM TechTool or take a look at Rhinoman's RhinoView software - he also has the cables to connect to the ECU - the connector is under the driver's side dash.
http://rhinopower.activeboard.com/
By the way - Rhinoman also has the jumper and flash code details in his web site.
Please note - Rhinoview is a work in progress - it may not include a complete configuration set for your ECU, but it's extensible.
Post Posted: Sat Mar 31, 2012 1:23 pm
Really, my experience is the opposite to what you are saying.
As an example I've got a lazy O2 sensor that will flash the CEL light in the same conditions every time, with it disappearing once I lift the throttle slightly & won't permanently light the CEL!
That error code will be stored on the ECU along with all the other errors until the battery has been disconnected & can be retrieved by using the jumping method.
Using the jumper method the CEL light will flash the error codes out as listed on the word document I posted in that other link.
Vehicle: 02 GV
Post Posted: Sat Mar 31, 2012 4:26 pm
Also just to add about reading fault codes, you cant use a ELM327 based OBD2 bluetooth adapter. well not in Australia but overseas models you can.
Post Posted: Sat Mar 31, 2012 7:19 pm
thanks atari, i will try it it out and see what it comes up with, im just downloading a program to view a doc file, so your doc is for a j20a but will still be applicable for my h20a?
Post Posted: Sat Mar 31, 2012 7:27 pm
they do differ slightly being a 6 cylinder, eg 2 o2 sensors & more coil packs but are essentially the same. i'll try & dig out the list of error codes for the H25a
Post Posted: Sat Mar 31, 2012 7:39 pm
only have the error codes for the H25a, but they'll be the same as the H20a
Post Posted: Sat Mar 31, 2012 9:07 pm
sweet, thanks alot :) i might check it out tomorrow
Vehicle: 1999 Jimny
Post Posted: Sun Apr 01, 2012 7:30 am
Okies, since I'm new to the GV scene I take it that the comp is what they call OBD2?????? If so there are apps for your phone that require a blue tooth adapter.
Post Posted: Sun Apr 01, 2012 9:04 am
they don't work on suzuki's as they run a different protocol even thought they have an OBDII plug (On Board Diagnostics)
Post Posted: Mon May 27, 2013 8:48 pm
fordem wrote:
If the CEL isn't on, there are no active fault codes, so there's nothing to be read using the jumper method.
The Suzuki specifications do seem to suggest this but I've been playing around with my Vit ECU and I've noticed that I get an idle switch fault which remains stored as a current fault with the CEL off when the TPS is off idle, it seems that it needs to go through a couple of drive cycles clear before it gets moved to history. I don't use the jumper method but it seem logical that the fault could be read using the CEL method.
Most codes will definitely clear immediately the fault clears and can then only be accessed by a scan tool.
Users browsing this forum: No registered users and 426 guests
