It is currently Sun Nov 08, 2026 2:01 am
Post Posted: Sat Mar 31, 2012 12:41 pm
Can anyone work out wtf this sound is?
sounds like a dog panting, more audible from half way in the vid.
I can't pinpoint it other than it coming from the engine. At first, from in the car it sounded like the snorkel sucking air, but then i listened carefully and it wasnt coming from the snorkel head.
if i rev from idle to say 1200rpm the "panting" increases with revs, but goes away once the revs increase. not sure if its being drowned out by engine noise though.
Engine has new oil, new filters (air and oil) and new plugs, and its got about 15,000km on it since its rebuild.
Vehicle: 4wd
Post Posted: Sat Mar 31, 2012 1:01 pm
Sounds like a knock, but that could be video quality.
Watch out or you'll get sued.
Post Posted: Sat Mar 31, 2012 1:11 pm
Pour some water on your belts to eliminate belt noise.
Made in JP. Built in WA.
Post Posted: Sat Mar 31, 2012 1:17 pm
stockman - thats just the injectors (the ticking sound) - its the rasping / breathing kinda sound you can hear behind the ticking...
red89 - i was wondering about belt noise, but i've never heard a belt make a noise like this before?! lol - i'll give it all a squirt and see what happens.
Post Posted: Sat Mar 31, 2012 1:32 pm
wetting the belts made no difference at all... started by misting them and went through to soaking them and nothing changed.
it kinda sounds like its behind the timing cover? would a timing belt make a noise like that?
Post Posted: Sat Mar 31, 2012 1:36 pm
sounds terminal :lol:
get a 1/2m length of garden hose or a long screw driver & use it as a stethoscope
Post Posted: Sat Mar 31, 2012 3:11 pm
definitely appears to be around the timing cover area... screwdriver trick doesnt seem to be helping me isolate it =/
Post Posted: Sat Mar 31, 2012 4:43 pm
My Sierra did that.
Timing belt was hitting the cover,
due to worn out/poorly fitted grommets,
Move the timing cover, see if it stops or worsens.
Don't stick hands in moving motor bits
Post Posted: Sat Mar 31, 2012 4:45 pm
Just noticed its a 1.6.
It could be loose harmonic balance pulley/worn/loose keyway
Post Posted: Sat Mar 31, 2012 5:42 pm
pull the timing cover off and have a look, hard to say by just listening to a vid. if you want a hand pm me.
Post Posted: Sat Mar 31, 2012 7:15 pm
thanks guys =)
Post Posted: Sun Apr 01, 2012 7:50 pm
very similar sound to when my timing belt had slipped forward and was rubbing on the front cover. ill pm you now.
Post Posted: Sun Apr 01, 2012 8:39 pm
same with mine belt was rubbing on timing cover very similar sound
Post Posted: Wed Apr 11, 2012 7:23 pm
8O 8O 8O
Atari was right!!!! (kinda)
Replaced the timing cover and put new seals in (crank and cam) and no difference - the old cover was warped and had been "self clearanced" but the noise persisted... turns out it was the water pump! glad i got it sorted out before it failed on me. phew.
Users browsing this forum: No registered users and 104 guests
