https://auszookers.com/forum/
jimny rattle? (fixed)
https://auszookers.com/forum/viewtopic.php?f=5&t=31600
Author:  jonno_racing [ Sun Apr 01, 2012 9:42 pm ]
Post subject:  jimny rattle? (fixed)
ok so I'm hopeing some one else has had the same issue..
my Jim has a stock exaust.
a week or so ago I fitted up a tow bar, and it was rubbing on the exaust at the tail pipe.
a few days after it developed a "rattle". it sounds a bit like a heat shield and sounded like it was coming from beside gearbox on passingers side. it is at about 3000-4500rpm at around half throttle.
it sounds a lot like a heat shield but kind of like a bearing rattle from the gearbox....
I re-made mounts for towbar a few days ago and rattle had got a whole lot quieter, not quite gone. I also checked exaust, and all the stupid heat shields feel tight,
today the rattle is back. and a little worse, it now makes the same rattle off the the throttle..
I'm thinking its the cat colapsing? I tried to remove shields off the exaust/cat however the bolts are well and truely seezed.
do you guys think its worth grinding the bolts off the covers, and to see if that's the issue?
or any other ideas?
Author:  31zook [ Sun Apr 01, 2012 10:04 pm ]
Post subject:  Re: jimny rattle?
6 sided socket and WD-40 ;)
Sounds like if it started only after the tow bar then it's a tow bar rubbing on your zorst... That or your muffler bearings are on there way out.
Author:  SierraDan [ Sun Apr 01, 2012 10:07 pm ]
Definitely muffler bearings.
Replace them then fit blinker fluid injection to the grease nipple.
Author:  jonno_racing [ Mon Apr 02, 2012 6:30 am ]
its a wierd one as the rattle is coming from way up front.
if its lunged a gbox or xcase, that's cool I have spair of each.
I was thinking of pulling out cat and bashing internals out of it, however it has bends either end of joins before cat.
Author:  jimny_timmy [ Mon Apr 02, 2012 9:34 pm ]
I'm 90% certain it's still your towbar... Mine was the same till I got my
2" exhaust and the fella that did it slightly changed its route to miss it
Author:  jonno_racing [ Mon Apr 02, 2012 10:54 pm ]
my towbar clears the exaust buy a good 40mm all round...
however it could be twist under load.
Author:  Mike57 [ Tue Apr 03, 2012 8:16 am ]
The rear muffler is located on rubber hangers. Mine can move quite a bit and I sometimes hear it hitting the tow bar. Grab the muffler and move it around to see if you can duplicate the noise you are hearing. Since it started after you fitted the tow bar this is the first clue about where to look I think.
Author:  jonno_racing [ Wed Apr 04, 2012 11:49 am ]
rattle found!
if you get under the Jim and shake shit out of exaust, you can actually feel something shacking about in the cat!
also even when shacking the zorst as hard as I can the rear muffler only just touches towbar
Author:  31zook [ Wed Apr 04, 2012 1:04 pm ]
Broken engine mount?
Author:  jimny_timmy [ Wed Apr 04, 2012 3:41 pm ]
Prob your set of pearl ear rings in the ashtray :p :thefinger:
Author:  jonno_racing [ Wed Apr 04, 2012 4:05 pm ]
did you read the post above yours???
hahah id say a bit of the cat has come loose.
Author:  jonno_racing [ Thu Apr 12, 2012 7:28 pm ]
found issue
