Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
Posted: Mon Apr 02, 2012 2:17 pm
In my green Zook, 94 WT with baleno coil pack motor the brakes do funny things. When the car is turned off the brake pedal feels nice and tight. Exactly how it should be. However web the car has revs up the brake pedal becomes soft.
Brakes are bled, baleno booster hose goes to the booster. What other things could it be? Stuffed master? Once it's idling brake pedal comes back. Turn it off it's nice an hard and tight again.
It still brakes fine without any dramas. Just goes a bit squishy.
Get in the car and pump the pedal till it is HARD. If this takes more than 2 pumps there are other problems.
Hold the pedal down and start the engine..... If the pedal sinks just a bit more the booster is working, if the pedal doesn't move upon starting engine, the booster is stuffed or not working.. I've seen PCV's installed backwards do similar things.
Users browsing this forum: No registered users and 101 guests
