https://auszookers.com/forum/
vitara carby onto sierra ??
https://auszookers.com/forum/viewtopic.php?f=5&t=31674
Author:  supa_slim [ Thu Apr 05, 2012 6:41 pm ]
Post subject:  vitara carby onto sierra ??
Is it possible to get a vitara carby on a Sierra to idle low ???
Author:  SuziBlu [ Fri Apr 06, 2012 1:03 pm ]
Post subject:  Re: vitara carby onto sierra ??
Wouldn't it be a simple idle speed screw adjustment ?
Can't see why it would be hard.
Author:  supa_slim [ Fri Apr 06, 2012 1:22 pm ]
The idle speed screw is wound all the way out
Author:  Daves4wd [ Fri Apr 06, 2012 1:26 pm ]
Check your throtel cable and make sure you have the wiring the right way around hope it helps
Author:  SuziBlu [ Fri Apr 06, 2012 1:28 pm ]
ok, not being silly, but is the throttle cable holding up the revs, have you moved the butterfly fully shut to see ?
I put a vitara carb on a mates sierra for him, and all that was needed was to idle down a touch, and jet down a bit, as it was rich as, but idle was just the screw.
Author:  supa_slim [ Fri Apr 06, 2012 1:33 pm ]
Nope cable isn't tight
Any other ideas
Author:  SuziBlu [ Fri Apr 06, 2012 1:37 pm ]
Have you pulled the top off n looked down the throat, see if the choke is on, really doesn't take much to make it rev, physically touch the butterfly, see if it moves more to the upright position.
Author:  SuziBlu [ Fri Apr 06, 2012 1:39 pm ]
Other than that, I have little ideas, maybe the idle up actuator is holding revs up, turn on the lights, see if it revs up further, if not, its the actuator stuck on.
Author:  supa_slim [ Fri Apr 06, 2012 1:42 pm ]
I'll try all that and see if anything happens
Author:  SierraDan [ Fri Apr 06, 2012 2:16 pm ]
Check the choke?
Author:  supa_slim [ Fri Apr 06, 2012 11:49 pm ]
Was the choke :)
Author:  2stroker [ Sat Apr 07, 2012 6:13 am ]
Vacuum leak ?
Author:  SuziBlu [ Sat Apr 07, 2012 8:02 am ]
Happy ending, cooooool.
