It is currently Sun Nov 08, 2026 2:02 am
Vehicle: 02 GV
Post Posted: Sun Apr 08, 2012 2:30 pm
listed on Giz international website as part of there lift kit
http://www.giz.com.tw/english/product_d ... pid=4&Id=7
Post Posted: Sun Apr 08, 2012 2:47 pm
I'm guessing 'avert incline' means 'anti roll' or SWAY BAR drop brackets.
Vehicle: 02 GV
Post Posted: Sun Apr 08, 2012 3:11 pm
I can see now, they bolt the chassis and the sway bar bolts to these.
but what the point.
Post Posted: Sun Apr 08, 2012 3:25 pm
With a lift your diff moves away from the chassis. So the swaybar is harder to hookup.
This kind of fixes that issue.
Vehicle: 02 GV
Post Posted: Sun Apr 08, 2012 3:36 pm
diff doesn't move on the front of a vitara and there's no sway bar on the rear.
Vehicle: Yellow Ute
Post Posted: Sun Apr 08, 2012 3:42 pm
Gee I guess you don't need it then.
Post Posted: Sun Apr 08, 2012 3:46 pm
They are front sway bar relocation brackets. With the front lifted, you may find it harder to get the sway bar to hook up, it will want to bind. We've found this with stock Vitaras arms and substantial lift in the past. The more the sway bar has to drop to reach the arms, the more the arm end mount won't line up as the sway bar is now too short (front to back) Hope that makes sense.
The spacers will bring the sway bar rearwards to compensate.
Vehicle: 02 GV
Post Posted: Sun Apr 08, 2012 7:33 pm
never had a sway bar hooked up with my vitara and my don't have that problem with my GV. maybe cause the GV hooks up from the rear and not the front like the vitara.
Post Posted: Mon Apr 09, 2012 9:37 am
You asked a question and you were given the answer, it is a sway bar relocation bracket used if you lift your vitara AND still want to use the sway bar.
Vehicle: 1995 Suzuki Vitara JX LWB G16B
Post Posted: Wed Apr 11, 2012 1:21 pm
Are these made for Sierras? i wan't to keep my front sway bar if i can
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Wed Apr 11, 2012 2:23 pm
Yep..
Post Posted: Thu Apr 12, 2012 9:55 am
Sierra's handle better when lifted without the sway bar...Mine did.
Vehicle: SJ80, SE416
Post Posted: Thu Apr 12, 2012 10:31 am
I've found my lifted coilies handle much better on-road with the sway bar retained. A 40mm lift will put a lot of pressure on the sway bar to the point that the sway bar limits suspension downward travel as the stock bar is not long enough to compensate for the lift and this stiffens the front end quite noticeably as the sway bar is always tight even on level surfaces. So my coilies handle like go karts on-road and tend to feel quite stable through corners rather than feeling like rolling over when you drive around roundabouts at 60km/h.
The biggest differences were felt after addding an exo cage. The added weight up high caused the Sierra to flex up in corners even at slow speeds - much less noticable with a sway bar attached.
Post Posted: Thu Apr 12, 2012 11:01 am
Without the sway bar dropped the front end is too tight in my opinion.. Makes the front understeer too much. Maybe being dropped its better?
But I have no issues without the swaybar anyway. Handles very well.
Post Posted: Thu Apr 12, 2012 11:19 am
Coilers have much lower rear roll stiffness than a leaf car, so the sway bar might have a bigger effect on balancing the handling.
(having said that, the Coilers I've been involved with had their sway bars pulled.
Users browsing this forum: No registered users and 85 guests
