It is currently Sun Nov 08, 2026 1:55 am
Post Posted: Wed Apr 11, 2012 7:25 pm
G'day
I own a 1998 SJ80 Coily, i currently have 2 inch raised King-springs on the front and rear and im running Suzi-sport Shockies (Ultima Brand) all round.
I've been driving with these for over 6 months and have regretted purchasing the Shockies, I've had to return two rears already due to leaking oil and even when they are working fine they're still terrible, you definitely get what you pay i guess.
If anyone knows of a different brand and part number if possible that i can use on the rear I'd appreciate it.
Cheers Dec
Post Posted: Wed Apr 11, 2012 7:37 pm
Just measure your closed and opened lengths, take those measurements to anywhere that sells shockies and match the lengths in the brand you want.
Post Posted: Wed Apr 11, 2012 7:43 pm
Thanks Rusho, that was my next plan, can you give me any brand that would be best? I've been told Rancho.
What do you run? If you still have the original coily set up that is.
Post Posted: Wed Apr 11, 2012 7:59 pm
Haven't had much to do with Rancho...from what I have heard they are crap. You want something that is valves to suit the cars weight. As much as I hate to say it, maybe Pedders or even cheap Munro gas shocks from repco
Post Posted: Fri Apr 13, 2012 3:42 am
Hello,
I'm new at auszookers and i'm from israel.
i've also having problem finding rear shocks, just moded monroe senstrac for the front and i was really suprised from how good they worked.
but rears with 43cm exteneded i can't find at any brand except from kyb which look too cheap..
i hoped to find some driections here.
i also have 2" raised springs , from tjm, i guess they are the same as yours.
Post Posted: Fri Apr 13, 2012 4:07 am
Nothing wrong with KYB.
Post Posted: Sat Apr 14, 2012 2:40 am
i'm looking into something more heavy-duty cause i'll be carrying almost extra 300kg by default.
btw. this is my front monroe sensatrac (originally made for ford bronco)
https://lh6.googleusercontent.com/-D3o5 ... titled.png
Vehicle: Coil Sierra
Post Posted: Sat Apr 14, 2012 7:55 am
If your looking for a common shock to use thats heavy duty try the NL pajero (1997 - 2000) (coil spring model) i used them in the rear of mine. But you will need a longer coil springs, i used jimny fronts with a coil spacer. I found them to be too heavy duty for light loads. Even better would be a 40mm lift jimny front coil spring with a spacer. this also results with better down travel as you can see in the picture...
Users browsing this forum: No registered users and 106 guests
