It is currently Sun Nov 08, 2026 4:26 am
Post Posted: Thu Apr 12, 2012 6:05 pm
As topic says. Anybody got one they can send me or point me out to. Thanks
Vehicle: '94 suzuki maruti
Post Posted: Thu Apr 12, 2012 6:15 pm
dont know if theyre the same, but i have a full sj413 manual on my computer, with a wiring diagram at the back. i know my maruti has the same wire colours, with a few minor differences . can send ya that if its any good to you...
Post Posted: Thu Apr 12, 2012 6:19 pm
Nah your running the 2 plug alternator. I'm running a 1 liter loom an 3 plug alternator. Got a battery and brake light and try to figure shit out. Doesn't turn off when ignition on.
An car running I should say.
Post Posted: Thu Apr 12, 2012 9:17 pm
pretty sure this is right one
Post Posted: Fri Apr 13, 2012 4:20 am
You Tha Man!
Post Posted: Fri Apr 13, 2012 4:32 pm
Does anyone know where the standard voltage regulator is on a SJ 1 liter.
Post Posted: Fri Apr 13, 2012 4:40 pm
Is under dash near passenger floor well, over a shelf thing
Post Posted: Fri Apr 13, 2012 4:55 pm
I'll scan you one from my workshop manual and email it to you.
www.bulldogtrimming.com
Post Posted: Fri Apr 13, 2012 5:13 pm
Thanks mate. Still have my email? Any of you guys put a 1.3 in a 1 liter using the internal reg alternator? Or changed to an internal reg one on a 1 liter. I cbfed playing with the external reg when I have 5 or so working Sierra alternators laying about. Some info would be sweet
Post Posted: Fri Apr 13, 2012 5:31 pm
I used a stock 1.3 internal regulated alternator, and bypassed the external reg this way.
Post Posted: Fri Apr 13, 2012 5:34 pm
Hey man. Do ya mind a chat? Can you pm me ya number.
Post Posted: Fri Apr 13, 2012 5:47 pm
My poor hearing makes phones difficult.
Best to communicate in writing.
I had a auto elec rig the regulator bypass for a cash donation to his bar fridge.
Going out now, feel free to ask away, if I can help I will.
Post Posted: Fri Apr 13, 2012 5:50 pm
call shep, he was always a guru with the electrical strings :lol:
Post Posted: Fri Apr 13, 2012 7:58 pm
Ok. So basically near the battery the loom 'protector' has rubbed raw and eventually worn through to the white with yellow stripe wire off the alternator to battery to fuse box wire. It had burnt through and stopped the alternator charging. It brought up the battery light, as well as the 'brake' brake oil low warning light. I replaced the wire from alternator to battery and battery to fuse box. I replaced all fuses. The alternator is now charging at about 14 volts however I still have the warning lights up.
Looking at diagram supplied the Reb with black stripe is the only thing that connects both lights. They are part of the same circuit. What should I check? Is the external regulator fubar?
Post Posted: Fri Apr 13, 2012 11:14 pm
Some external regs can stick, especially after a short, or if water gets in etc.
If you fixed all issues,
try a tapping on reg, it may fix it.
I think the main charge wire to battery is a fuseable link.
Not supposed to fit normal wiring.
I found that out 7 years after fitting normal wire to mine :oops:
Never had a problem though.
Post Posted: Fri Apr 13, 2012 11:46 pm
It is a fusible link. However didt blow. I'll give it a good smack.
Post Posted: Sat Apr 14, 2012 8:59 am
How does one test an external regulator to make sure it's switching to the dash to turn the lights off. When the car runs its charging at 14.1 ish volts at about 2000 rpm.
Users browsing this forum: No registered users and 105 guests
