It is currently Sun Nov 08, 2026 2:01 am
Post Posted: Thu Apr 12, 2012 6:55 pm
Can you run a LH rear brake cylinder in the right drum?
Mine has one and I keep having brake problems. Should I get the crossover line and go back to original LH and RH cylinders?
Post Posted: Thu Apr 12, 2012 7:08 pm
Sorry guys it's an 85 NT with 92 WT diffs.
Post Posted: Fri Apr 13, 2012 4:28 pm
NT and WT run different rear wheel cylinders.
You say you have WT diffs but what backing plates/brakes do you have? NT 2 hose or WT 1 hose?
Post Posted: Fri Apr 13, 2012 5:32 pm
I have the WT backing plates
Post Posted: Fri Apr 13, 2012 7:08 pm
The WT rear cylinders are different side to side and both different to NT.
Post Posted: Sat Apr 14, 2012 5:32 am
Generally speaking - the differences in rear wheel cylinders are in the bleed arrangements - and once they are "plumbed" correctly, there's no reason why they can't be swapped from side to side.
What is the nature of the problem you keep having?
Post Posted: Sat Apr 14, 2012 6:05 am
I can't get any pedal until the second pump of the brakes no matter how many times I bleed them. I looked for the bleeder under the drivers floor pan on the chassis rail that some WT's have but can't seem to find one.
I checked the booster and it's fine.
I just thought it was because someone put 2 left cylinders on.
Post Posted: Sun Apr 15, 2012 9:03 am
Bleeding is done to get rid of trapped air - not being able to get any pedal until the second pump doesn't sound like trapped air to me.
Trapped air will usually result in the pedal being soft or "spongy" - which you don't mention - what does your pedal feel like on the second pump?
Recheck the adjustment on the rear drums and go over the front calipers carefully - something is pushing a piston back into it's cylinder so that you have to pump to get it out before you can apply pressure - loose wheel bearings, stuck caliper slide pins
Post Posted: Sun Apr 15, 2012 4:34 pm
Wear seems to me.
Post Posted: Sun Apr 15, 2012 10:09 pm
I got sick of having no brakes so I pulled them all off, slide pins were siezed on one side and the rear shoes had no meat lefton them! I only changed them 6 weeks ago and i'm lucky to drive the old girl once a week!!! If I have to do the drums this often it's time for a rear disc conversion.
Post Posted: Mon Apr 16, 2012 8:44 am
Welcome to the world of shitty drum brakes and mud.
Users browsing this forum: No registered users and 106 guests
