It is currently Fri Nov 06, 2026 9:37 pm
Vehicle: LWB Sierra & XL7
Post Posted: Thu Sep 06, 2012 2:16 pm
Howdy,
Since the under dash fuse panel cover is missing in my Sierra, I'm wondering if the fuses in there are the correct amps and if it's normal to have a heap of empty slots.
Can someone please explain what fuse go's where, put up picture or draw a diagram.
Cheers.
'92 Vitara & Camper trailer
Post Posted: Thu Sep 06, 2012 2:33 pm
http://www.google.com.au/imgres?q=samur ... 0,s:0,i:70
Post Posted: Thu Sep 06, 2012 4:21 pm
Thanks for that.
[10A] [10A] [10A] [10A] [5A] [5A] [5A]
[15A] [15A] [15A] [15A] [10A] [10A] [15A]
Seems like I'll be changing a few tonight ;)
Post Posted: Thu Sep 06, 2012 5:33 pm
I just got home and had a closer look, my fuse box seems to have a different configuration. Somehow I don't think a 25A fuse would belong in there :/
Vehicle: 92 Suzuki Sierra
Post Posted: Thu Sep 06, 2012 6:29 pm
That link shows USA model wiring,
Great thing about the sierra is it has two fuses, 10a and 15a
Taken from my fuse cover for the 92 WT sierra, i can check the 85 LWB in the morning if its necessary
[10][10][10][15][15][15]
[15][15][15][15][10][15]
Its good to know what they are in case you need to pinch a fuse from somewhere not used (like heater or A/C)
also good to have the cover as it fits 3 spare fuses , from memory ANY 80's suzuki car will have the same size cover
Suzuki Sierra WT 92
Headlight R / Headlight -L / tail stop/ hazard horn / radio cigar / ACC
IG Coil - Meter / heater / rear defg / wiper washer / turn back / Air con
Keep in mind when diagnosing problems the above is a rough guide
when fixing a faulty radio issue with a friends suzuki lwb vit i discovered the dash lights no longer worked, checked fuses and ok... checked another fuse which seemed unrelated and it fixed it. The details are foggy but it sort of made sense at the time being a second circuit or something but lesson was learned. Check other fuses if it seems to be zero power.
Also while talking fuses, narva manual resetable blade fuses are worth the $10 when fault finding :D
Post Posted: Thu Sep 06, 2012 6:33 pm
This one shows 20A in the radio cigar so i guess that isn't too bad... but i like to errrr on the side of caution with fuses
Vehicle: SJ51T
Post Posted: Thu Sep 06, 2012 7:47 pm
My 87 Lwb and 92 wt are the same.
If you want a cover, I have one here you can have.
Post Posted: Thu Sep 06, 2012 8:28 pm
Those 4 empty spots on mine don't have any fuse holders. And there's no switch or anything for the diagnostic port.
I forgot to mention, Mine is a '92 WT Soft top.
Post Posted: Thu Sep 06, 2012 10:50 pm
the photo i put up was not of mine but the internet... so basically what i posted earlier is correct for you
Post Posted: Fri Sep 07, 2012 8:33 am
Thanks for the offer, I'm sure I'll find one from pocket a part
And thanks again Santos, :)
Users browsing this forum: Google [Bot] and 60 guests
