It is currently Sat Nov 07, 2026 10:01 pm
Post Posted: Sat Apr 28, 2012 5:22 pm
hi all, just wondering this has been happening alot, when driving for like 20mins in my 92 sierra all the coolant in the radiator flows into the overflow bottle and then all spills outta the overflow bottle, and all the coolant in the radiator what is left is all foaming. was just wondering if anyone knew why this would be happening? any help would be great cheers.
Post Posted: Sat Apr 28, 2012 5:25 pm
Sounds like the cylinders are pressuring the cooling system. Could be a headgasket
Lil Foot!
http://tiny.cc/gtsw1
Vehicle: Suzuki Jimny
Post Posted: Sat Apr 28, 2012 5:28 pm
Could be a faulty radiator cap
Post Posted: Sat Apr 28, 2012 7:42 pm
Head or head gasket.
Post Posted: Sat Apr 28, 2012 8:27 pm
I'd be putting my money on a head gasket or head it's happend in my other car witch was a rotary and it was caused by a corroded housing different engine but same thing pretty much applys
Post Posted: Sun Apr 29, 2012 11:04 am
i have replaced the radiator cap
Post Posted: Sun Apr 29, 2012 12:08 pm
caps not the problem you ether have a cracked head or a blown head gasket
 Profile YIM
Post Posted: Sun Apr 29, 2012 1:09 pm
Did the problem start after doing this? Is it a genuine cap?
Post Posted: Mon Apr 30, 2012 7:32 am
no the problem started before changing the cap
Post Posted: Mon Apr 30, 2012 2:08 pm
Xlots it's a head gasket.
Overheated it?
Vehicle: multiple R32's, wtd sierra
Post Posted: Mon Apr 30, 2012 3:06 pm
as all the above. 99.9999999% chance its the headgasket.
what colour is the radiator fluid? is there any milky-ness in there?
is there continuous small bubles coming up in the fluid when you have bled the system?
Post Posted: Mon Apr 30, 2012 5:04 pm
you may not get a colour change in the coolant if its just dropped the gasket between the cylinder and water gallery.
Yay for head gaskets, Get it compression tested if you still don't think its a head gasket. then we can say "theres your sign"
Stocker
Users browsing this forum: Google [Bot] and 91 guests
