It is currently Sun Oct 04, 2026 4:15 am
Vehicle: Suzuki sierra
Post Posted: Tue May 15, 2012 4:54 am
Do the sierras have a brash bush that holds the axle centeral
Post Posted: Tue May 15, 2012 5:13 am
There is one in the back of the hub spindle. I'm not sure that its purpose is to hold the axle central, but it does remove a little bit of float from the CV.
Post Posted: Tue May 15, 2012 5:24 am
I'm doing a complete overhaul in the front.just wondering should I replace that to
Post Posted: Tue May 15, 2012 5:28 am
Nope. They don't wear out. I've never even heard of somone replacing one.
Just do your inner oil seal, Felts, king pins, wheelbearings and dust seal, and re-grease your CV and locking hub assembly, and thats it.
Post Posted: Tue May 15, 2012 9:10 am
It seems the toyota guys change them because the axle seals must be abit shit.
If the axle seal wont seal. This bush can be the problem.
Im yet to change one.
Post Posted: Tue May 15, 2012 9:23 am
What is the name of them if I won't to get sone
Post Posted: Tue May 15, 2012 10:49 am
If you just explain where it is you should be able to order one.
Swivel hub brass bush
Vehicle: LJ50V, SJ70
Post Posted: Wed May 16, 2012 11:23 am
I don't think they're even available as a separate part, certainly not from Suzuki where it is an integral piece of the spindle. As others have said, I've never heard of anyone having to replace one because they flog out your axle seal.
Vehicle: 03 Jimny
Post Posted: Wed May 16, 2012 12:09 pm
Pretty sure you can't replace them. They are part of the spindle, so you would have to buy a new spindle hub.
Post Posted: Wed May 16, 2012 1:30 pm
The bush is brass/bronze, The knuckle/hub is not.
So.. they are replaceable.
Whether you can buy them or not is a different story.
Post Posted: Wed May 16, 2012 2:05 pm
/\ /\ X 2
I've never seen one that wasn't reuseable.
Users browsing this forum: No registered users and 190 guests
