It is currently Sat Oct 03, 2026 4:48 am
Post new topic Reply to topic  [ 30 posts ]
Vehicle: 03 Jimny
Post Posted: Thu May 17, 2012 5:45 pm
im rebuilding a wt transfercase atm and i cant seem to remove the shift fork out off the case. i manage to get it all apart, but i need the shift fork out to reinstall every thing back together. ive removed the detent ball but still doesnt budge. hit it with a soft mallet, even try pressing it out. any ideas?
cheers
Vehicle: 1985 Holden Drover
Post Posted: Thu May 17, 2012 6:54 pm
afaik you shouldnt have to remove the shift fork? If its the bit im thinking about?
1989 WT Sierra.
Vehicle: 03 Jimny
Post Posted: Thu May 17, 2012 7:37 pm
yea its got to come out. even the reduction gear instructions saids so.
Post Posted: Thu May 17, 2012 8:53 pm
With mine I had to knock out a roll pin! That's what my 4.9 instructions made me do.
My Maruti build, Click WWW
Vehicle: 03 Jimny
Post Posted: Thu May 17, 2012 8:58 pm
were is the pin located? ive got evey thing unscrew out of the housing accept the shift fork.
Post Posted: Thu May 17, 2012 9:20 pm
I've rebuilt dozens of sierra cases, and installed gears of different ratios, and I've never had to remove the shifter rods from the front housing. There are no seals or O-rings in their assembly, only detent balls, which can be a PITA to re-fit.
Vehicle: 03 Jimny
Post Posted: Thu May 17, 2012 9:48 pm
i cant put it back together. im having trouble. i have the gears installed into the rear housing, then when i go to put middle housing on, i cant get the fork around under the couter shaft gears to go onto the high/low gear
Post Posted: Thu May 17, 2012 9:54 pm
Lift the idler gear and the input gear up a little. The bearing at the base of the input gear will re-seat itself, as will the idler gear if you give it a little turn so they mesh together.
its an arkward motion, but it does work I assure you. I will have a case appart tomorrow, so if you are still struggling I will get some pics for you. ( with my 3rd hand :roll: )
Vehicle: 03 Jimny
Post Posted: Thu May 17, 2012 9:56 pm
thats would be good thanks :D
Post Posted: Thu May 17, 2012 11:46 pm
X2.
Vehicle: Daisy
Post Posted: Fri May 18, 2012 7:24 am
The rods should come out pretty easily. I've had trouble trying to move them because the detent ball locks them, if you twist the rail around, it will push the ball back and now your sliding on the part without the grooves for the balls to lock into, slide it wherever you need, turn it back.
If you take them out it can be a real struggle to get them back in, for reasons mentioned above. I think I used a screwdriver or similar to push the ball down far enough, slide it out as you slide the rail back in and hopefully all good...
Vehicle: 02 GV SQ625 + 84 Sierra SJ410
Post Posted: Fri May 18, 2012 7:35 am
Lift the idler gear and the input gear up a little. The bearing at the base of the input gear will re-seat itself, as will the idler gear if you give it a little turn so they mesh together. Its an arkward motion, but it does work I assure you.
+1
If your SE Brisbane I can come round and give you a hand.
Vehicle: 03 Jimny
Post Posted: Fri May 18, 2012 8:38 am
ive got the detent ball out off the case. it slides almost out and then gets cour about a inch from the end,
scorpydue, im 2hrs north of brisbane so pretty far. thanks for the offer though :D
Post Posted: Fri May 18, 2012 8:53 am
There is a detent ball between the two rods as well. You need to get the detent ball to sit in a notch on the rod you are not removing, then rotate the other rod. It should come out then.
But you have been warned.... Its a shitty job getting it all back together :x
Vehicle: 03 Jimny
Post Posted: Fri May 18, 2012 9:00 am
okay well im gonna try your idea soon fat, ill see if i can get it
Vehicle: 03 Jimny
Post Posted: Fri May 18, 2012 2:51 pm
I f#*ked it so gotta find another case now. Thanks for you help.
Post Posted: Fri May 18, 2012 3:24 pm
Yikes!
whatd you do to ruin it? so i can learn from your mistake when i do mine.
MY BUILD THREAD HERE!!!!!
Vehicle: 03 Jimny
Post Posted: Fri May 18, 2012 3:32 pm
Dont hit cast iron to hard
Post Posted: Fri May 18, 2012 4:57 pm
I thought the cases were only cast ally?
1989 WT Sierra.
Vehicle: 03 Jimny
Post Posted: Fri May 18, 2012 5:11 pm
Wasn't the case that broke
Post Posted: Fri May 18, 2012 5:20 pm
Haha, I can send you another selector if you like.
Vehicle: 03 Jimny
Post Posted: Fri May 18, 2012 5:36 pm
Wasn't selector either I smashed the teeth off the spline that te circlip goes into to hold the front output shaft sliding cog thing, also decked the thread on the end of the shaft
Post Posted: Fri May 18, 2012 6:29 pm
Sounds shit :cry:
Buy a copper mallet for your next attempt.
Post Posted: Fri May 18, 2012 6:49 pm
Not sure if this is any use to you, but I have a brand new main shaft here ( the bit with the spline you broke ). It owes me $180US plus freight, but if you bring your case and $200 down here on Sunday I'll press all your bearings etc onto the new shaft and show you how to fit it all.
I also have a new HD front output shaft, new internal needle roller for front output shaft, new speedo drive gear and housing, new rubber boot and spring for transfer shifter, thrust washers, O-rings, shifter bushes, prop shafts, gaskets etc....
Vehicle: 03 Jimny
Post Posted: Fri May 18, 2012 7:04 pm
Well I do need another case or either two new shaft. I'm I rough barsted and destroyed the rear out put and the front input shaft threads. Me being dogy tried cuting thread back to fix up but made a mess :( I new two new nuts aswell.
Every thing is good asides two shafts and two nuts.
Post Posted: Fri May 18, 2012 8:23 pm
I'll see if I have the other shaft you need in the morning. It will be used though.
And you can get new nuts from suzi auto spares at springwood. Just get him to post them to you on monday. Cheaper than LROR on the flange nuts BTW.
Vehicle: 03 Jimny
Post Posted: Fri May 18, 2012 8:30 pm
Don't mine if you have two used shaft or one.
Yea I'll order new nuts.
Pm sent
Post Posted: Fri May 18, 2012 8:32 pm
Pm sent
My main shaft was toast. Seems its getting more and more common to find them that way. Thats why I keep one here.......
Post Posted: Sat May 19, 2012 2:52 pm
http://www.lowrangeoffroad.com/index.ph ... shaft.html
is this the one you are referring to?
Vehicle: 03 Jimny
Post Posted: Sat May 19, 2012 5:15 pm
Yep that's the shaft I smashed the spline on.
Users browsing this forum: Google [Bot] and 216 guests
