It is currently Sat Oct 03, 2026 6:37 am
Vehicle: Suzuki sierra
Post Posted: Fri May 18, 2012 7:32 am
How do you check your timing belt
Post Posted: Fri May 18, 2012 7:49 am
What's the procedure
Vehicle: LJ80
Post Posted: Fri May 18, 2012 8:03 am
remove everything in front of the timing cover then remove the cover and have a look
Post Posted: Fri May 18, 2012 9:02 am
What are you hoping to see when you check it?
As a rule, you should CHANGE your timing belt every 100,000kms.
You should CHANGE it when you buy a car with more than 100,000kms, and no written ( or otherwise) record of it having been done.
You should CHANGE your timing belt if you have cam or crank seal leaks, as oil will degrade your belt ( change the offending seals whilst in there ofcoarse)
And you should CHANGE your timing belt if it snaps.
If you have satisfied the above, then leave it alone.
Post Posted: Fri May 18, 2012 9:53 am
Do the sierras have a timing belt light when it needs to be done like other vechicals
Post Posted: Fri May 18, 2012 9:56 am
Deego, not meaning to be rude but these type of questions you seem to be asking would be best reserved for the "N00b Talk". Noob refers to newby by the way. Noob talk is a more noob friendly section.
And no they do not have a light for timing belt service intervals.
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Fri May 18, 2012 10:07 am
Oh ok thanks I'll go there then
Vehicle: 1985 Holden Drover
Post Posted: Fri May 18, 2012 4:59 pm
You suggest doing the water pump at the same time as the belt seeing as its off anyway? Gotta get on to doing mine soon!
1989 WT Sierra.
Post Posted: Fri May 18, 2012 6:26 pm
Its up to you. It doesn't sit behind the timing cover on a G motor like some others do, but you still need to remove a bit of stuff thats in the way. So yeah, I guess thats not a bad idea.
Post Posted: Sat May 19, 2012 7:00 am
by doesn't sit behind the timing cover you mean the timing belt tensioner bolts to it right :thefinger:
My theory is if its an even number of km, IE 200000 400000 then do the pump
Users browsing this forum: No registered users and 183 guests
