It is currently Sat Oct 03, 2026 8:19 am
Vehicle: 98' SJ80 lifted on 30s
Post Posted: Fri May 18, 2012 4:46 pm
I was looking through the CAlmini 2011 catalog and I came across their 3" coil sidekick lift kit and want to know how good is their equipment and will it fit my SJ80 coil Sierra if not do you know if they make a kit for my zook.
The other is I like the look of the LSD they produce does anyone have that LSD and if someone could tell me if a SJ413 rear LSD/diff will suit my SJ80... If not maybe would the rear LSD/ diff of a 95-98' sidekick/ tracker match my SJ80 coily.
Help is muchly appreciated ;)
Post Posted: Fri May 18, 2012 5:05 pm
calmini don't do anything for the SJ80's... the Sidekick/Tracker is the US version of our Vitara
the SJ413 LSD will fit the rear of your coily SJ80.
Post Posted: Fri May 18, 2012 5:08 pm
They never have the lsd and they cost a fortune
Better of with a cheap copy airlocker
They will not have suspension for a coily as they never got them in the us
And their springs and shocks suck Anyway
Post Posted: Fri May 18, 2012 5:24 pm
really, at least my struts don't fall out like your ODA equipped POS! :thefinger: pompoms
Post Posted: Fri May 18, 2012 5:43 pm
The strut is fine it was the cheap shit spacer that was the problem
If u want sething made right do it yourself
Didnt u have to add bumpstop spacers because ur springs bound before the bump stop touched
I have never read anywhere any one that like the shocks in the kit
Post Posted: Fri May 18, 2012 5:52 pm
pretty sure bumpstop extensions are required with any 3" lifted vitara, not just vitara's running the calmini kit... thought that was common knowledge. :wink:
i'd rather be running the calmini kit than the booty fab set up in yours.
Vehicle: Serria
Post Posted: Fri May 18, 2012 6:26 pm
I have a set of 4 inch springs for a sj80 if you are interested
Sj80 cab on sj70 chassis 5inch lift 1.6 turbo inte
Post Posted: Fri May 18, 2012 6:37 pm
Thanks for the notes guys.
Post Posted: Sat May 19, 2012 1:10 am
On the LSD page it says they're sold out/no longer in production, easy to miss that. :(
Users browsing this forum: No registered users and 201 guests
