It is currently Thu Oct 01, 2026 3:53 am
Post Posted: Sun May 20, 2012 5:47 pm
can anyone give me any advise on what to do or should i just get a new box?
i took the selector off the topof the box and couldnt budge the gear fork
Vehicle: 2018 DMAX
Post Posted: Sun May 20, 2012 7:02 pm
So it stuck in gear with the stick still in the box?
Post Posted: Sun May 20, 2012 10:43 pm
yer with the leaver in
i can move the selector side to side but it wont come outs first
Post Posted: Mon May 21, 2012 8:51 pm
so nobody can help me?
Post Posted: Mon May 21, 2012 9:08 pm
Can you take the shifter out of the gearbox, and get a pic of the selector rods beneath? They may need to be realigned.
Also is the shifter bush still intact?
Vehicle: 2018 DMAX
Post Posted: Tue May 22, 2012 8:48 am
This is what I was thinking, but I couldn't see how it could happen with the shifter still in place :?
Vehicle: '96 LWB trayback
Post Posted: Tue May 22, 2012 9:07 am
If the end of the shifter is worn (rounded corners) It can jam in gear while still in place. Have had it happen to me on occasions during some fast n furious low range shifting.
As above, pull the stick, check the shift rods are aligned correctly. They should form a square hole like this: [ ]
I'd suspect one of yours is offset.
Post Posted: Tue May 22, 2012 11:17 am
Its the same problem the transfers get.
Check that the shifter bush is in good condition. Check that the locator bolt is still there ( it keys into the slot on the ball of the shifter), and check that the shifter rods are aligned.
Post Posted: Tue May 22, 2012 1:26 pm
some helpful tech & pics in this thread viewtopic.php?f=5&t=12104&hilit=shifter+bolt
Post Posted: Tue May 22, 2012 7:23 pm
ok thanks guys in have a look and if i have dramas ill put some pics up cheers guy's
Users browsing this forum: No registered users and 124 guests
