It is currently Tue Nov 10, 2026 5:42 pm
Post Posted: Mon May 21, 2012 9:59 pm
i have just found some time to finish my transplant of a g13b engine into my sierra. i have made a complete new wiring harness using the swift harness i got with the engine. i am having trouble getting the engine to run, it starts, has oil pressure, runs for about 10 seconds and stops. is there any advice of things to look for? the only thing i may not have done, is given the computer a signal from the oil pressure switch. plenty of fuel, engine runs sweet when it starts, but wont run any longer than 10 seconds
any help would be appreciated.
also looking for zookfun if he is still on the forum, can he please PM me.
Vehicle: SJ51T
Post Posted: Mon May 21, 2012 10:19 pm
dodgy AFM maybe. jump on redline and search for how to test to see if your AFM is within spec.
do you have your check engine light hooked up? if you do check for error codes.
Turns out ive got it book marked! lucky you
http://www.redlinegti.com/images/person ... 6e1-48.jpg
Post Posted: Tue May 22, 2012 8:21 am
Your ecu doesnt need oil pressure signal and it shoud still run with a dodgy AFM. Have you got a rpm signal from your coil to the ecu? some thing that i messed up on one time. also what mrk is it? What dizzy set up have you done, not that dodgy mazda cap idear .
Vehicle: SJ51T
Post Posted: Tue May 22, 2012 8:42 am
I had a dodgy AFM, it would stall after about 5 seconds tho. replaced it and it was all good.
How is the mazda cap dodgy? I'm not being an ass im just curious.
Post Posted: Tue May 22, 2012 9:14 am
what mk is it?
Post Posted: Tue May 22, 2012 1:27 pm
its a mark 3 engine. i have used the dizzy that came with the engine, i installed my engine forward slightly, so the stock dizzy fits with no right angle drive. worked out well, gearbox lines up with hole better too. trying to get hold of another AFM, i have the workshop manual, which shows how do diagnose the afm, trying that tonight
Post Posted: Tue May 22, 2012 1:50 pm
Much better useing the right cap, I mite have a spare AFM if you get suck, sensor are getting hard to get for these engines. I have factory work shop books if you get stuck
Post Posted: Tue May 22, 2012 5:28 pm
thanks heaps for that, got another afm coming from a guy from redlinegti forum, plus have the workshop manual in PDF format. not sure if it is the mark 3 manual though, any differences?
i'll see how i go, should know something by the weekend.
will find some pics to put on. cheers
Post Posted: Tue May 29, 2012 8:58 pm
ok, put new afm on the engine, no difference. however i have found that the engine is starving for fuel. i am using a bosch high pressure electric fuel pump. does anyone have a diagram of how the fuel system should be plumbed up. i am getting plenty of fuel up to the engine but not much going into the injectors. any help?
Users browsing this forum: Google [Bot] and 108 guests
